Unmounting a General-Purpose File System
If a general-purpose file system is no longer used and you want to delete it, you are advised to unmount the file system and then delete it.
Stop the process and read/write operations before you unmount a general-purpose file system.
Linux OS
- Log in to the ECS console.
- Unmount the file system.
umount <local-path>
Variable <local-path> is an ECS local directory where the general-purpose file system is mounted, for example, /local_path.
Before running the umount command, stop all read and write operations related to the general-purpose file system and exit from the local path. Otherwise, the unmounting will fail.
