Updated on 2026-10-10 GMT+08:00
WAF
Function Description
This plugin has been built into SecMaster. It can call Web Application Firewall (WAF) APIs to manage WAF resources, such as protected domain names, policies, IP address groups, blacklists, and whitelists.
Each built-in plugin has a corresponding built-in operation connection.
Viewing Details and Operation Connections of the WAF Plugin
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Security Orchestration > Plugins.
    Figure 2 Plugins page
  5. On the Plugins page, select the WAF plugin under the Huawei Cloud catalog. The Details tab is displayed by default. The Details tab displays the login credential information of the operation connection associated with the plugin.
  6. Click the Operation Connections tab for the WAF plugin. On the displayed page, you can view information about the operation connections associated with the plugin.
  7. For details about how to edit or delete an operation connection, see Editing an Operation Connection and Deleting an Operation Connection. For details about how to add an operation connection for a plugin, see Creating an Operation Connection. A plugin can have multiple operation connections.
Plugin Execution Function createIpGroup
Parameters of the createIpGroup Function
Function: Creates an IP address group.
Table 1 Input parameters of the createIpGroup function
Parameter Type
Parameter Description
Mandatory
name
String
IP address group name.
Yes
ips
String
IP address list. Use commas (,) to separate multiple IP addresses.
Yes
description
String
IP address group description.
No
enterprise_project_id
String
Enterprise project ID. You can obtain it by calling the ListEnterpriseProject API of Enterprise Project Management Service (EPS).
No
agency_type
String
Unified adaptation parameter for multi-account management. Use the default value.
No
Table 2 Output parameters of the createIpGroup function
Parameter Type
headers
Object
API response headers, including basic information about the request and response, such as the request time, response service, and request ID.
code
Int
Status code, which indicates whether the request is successful.
Response code description:
  • If the value of code is 200, the request is successful.
  • If the value of code is 401, the account or password is incorrect.
  • If the value of code is 403, the permission is insufficient.
  • If the value of code is 404, the requested resource does not exist.
body
Object
Content returned by the API.
Output Example of the createIpGroup Function
  "headers": {
    "Transfer-Encoding": "chunked",
    "Server": "api-gateway",
    "X-Request-Id": "f7e759ff25266227a1d31f5068a5b3ed",
    "X-Content-Type-Options": "nosniff",
    "Connection": "keep-alive",
    "X-Download-Options": "noopen",
    "Pragma": "no-cache",
    "Date": "Mon, 25 May 2026 09:10:00 GMT",
    "X-Frame-Options": "SAMEORIGIN",
    "Strict-Transport-Security": "max-age=31536000; includeSubdomains;",
    "Cache-Control": "no-cache, no-store, max-age=0, must-revalidate",
    "X-XSS-Protection": "1; mode=block;",
    "Content-Type": "application/json; charset=UTF-8"
  "code": 200,
  "body": {
    "id": "ipg-12345678",
    "name": "test-ip-group",
    "ips": "192.xxx.1.1,xx2.168.1.2",
    "description": "Test IP address group",
    "size": 2
Plugin Execution Function deleteIpGroup
Parameters of the deleteIpGroup Function
Function: Deletes an IP address group.
Table 3 Input parameters of the deleteIpGroup function
Parameter Type
Mandatory
id
String
IP address group ID. You can obtain it by calling the ListIpGroup API.
Yes
String
No
agency_type
String
No
Table 4 Output parameters of the deleteIpGroup function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the deleteIpGroup Function
  "headers": {
  "code": 200,
  "body": {}
Plugin Execution Function updateIpGroup
Parameters of the updateIpGroup Function
Function: Updates an IP address group. You can add or remove IP addresses.
Table 5 Input parameters of the updateIpGroup function
Parameter Type
Mandatory
ipGroupId
String
Yes
name
String
No
ips
String
IP address list.
No
description
String
No
enterpriseProjectId
String
No
action
String
This parameter is mandatory when an IP address group is modified.
Value range:
  • add
  • delete
  • update
No
agency_type
String
No
Table 6 Output parameters of the updateIpGroup function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the updateIpGroup Function
  "headers": {
  "code": 200,
  "body": {
    "name": "updated-ip-group",
    "ips": "192.xxx.1.1,192.xxx.1.2,192.xxx.1.3",
    "description": "Updated IP address group",
    "size": 3
Plugin Execution Function listIpGroup
Parameters of the listIpGroup Function
Function: Queries the IP address group list.
Table 7 Input parameters of the listIpGroup function
Parameter Type
Mandatory
name
String
No
page
Integer
Page number of the pagination query. If this parameter is not specified, the query starts from the first page by default.
No
pagesize
Integer
Page size of the pagination query. If this parameter is not specified, 10 records are displayed on each page by default. The maximum value is 100.
No
enterpriseProjectId
String
No
ip
String
Specific IP address or IP address range for the query.
No
Table 8 Output parameters of the listIpGroup function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listIpGroup Function
  "headers": {
  "code": 200,
  "body": {
    "total": 10,
    "items": [
        "ips": "192.xxx.1.1,192.xxx.1.2",
        "size": 2
Plugin Execution Function createPolicy
Parameters of the createPolicy Function
Function: Creates a protection policy.
Table 9 Input parameters of the createPolicy function
Parameter Type
Mandatory
name
String
Policy name. The policy name can contain only digits, letters, and underscores (_) and cannot exceed 64 characters.
No
enterpriseProjectId
String
No
agency_type
String
No
Table 10 Output parameters of the createPolicy function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the createPolicy Function
  "headers": {
  "code": 200,
  "body": {
    "id": "policy-12345678",
    "name": "test-policy",
    "level": 1
Plugin Execution Function deletePolicy
Parameters of the deletePolicy Function
Function: Deletes a protection policy.
Table 11 Input parameters of the deletePolicy function
Parameter Type
Mandatory
policy_id
String
Protection policy ID. You can call the ListPolicy API to obtain the policy ID.
Yes
String
No
agency_type
String
No
Table 12 Output parameters of the deletePolicy function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the deletePolicy Function
  "headers": {
  "code": 200,
  "body": {}
Plugin Execution Function showPolicy
Parameters of the showPolicy Function
Function: Queries details about a protection policy.
Table 13 Input parameters of the showPolicy function
Parameter Type
Mandatory
policyID
String
Yes
enterpriseProjectId
String
No
Table 14 Output parameters of the showPolicy function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the showPolicy Function
  "headers": {
  "code": 200,
  "body": {
    "level": 1,
    "full_compliance": true
Plugin Execution Function queryPolicyList
Parameters of the queryPolicyList Function
Table 15 Input parameters of the queryPolicyList function
Parameter Type
Mandatory
enterpriseProjectId
String
No
page
Integer
Start page number for the pagination query.
No
pagesize
Integer
Number of data records on each page for the pagination query.
No
name
String
Policy name.
No
agency_type
String
No
Table 16 Output parameters of the queryPolicyList function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the queryPolicyList Function
  "headers": {
  "code": 200,
  "body": {
    "total": 10,
    "items": [
        "level": 1
Plugin Execution Function createPunishmentRule
Parameters of the createPunishmentRule Function
Function: creates a known attack source rule to block IP addresses of a specific type.
Table 17 Input parameters of the createPunishmentRule function
Parameter Type
Mandatory
policyId
string
Policy ID.
Yes
category
string
Category.
Yes
blockTime
string
Block duration (min).
Yes
description
string
Description.
Yes
enterpriseProjectId
string
No
agency_type
string
No
Table 18 Output parameters of the createPunishmentRule function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the createPunishmentRule Function
  "headers": {
  "code": 200,
  "body": {
    "id": "punishment-12345678",
    "name": "Known attack source rule",
    "punishment_time": 300,
    "punishment_action": "block"
Plugin Execution Function listPunishmentRule
Parameters of the listPunishmentRule Function
Function: Queries the known attack source rule list.
Table 19 Input parameters of the listPunishmentRule function
Parameter Type
Mandatory
policyId
string
Policy ID.
Yes
enterpriseProjectId
string
No
offset
string
Offset.
No
limit
string
Number of records on each page.
No
Table 20 Output parameters of the listPunishmentRule function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listPunishmentRule Function
  "headers": {
  "code": 200,
  "body": {
    "total": 10,
    "items": [
Plugin Execution Function createWhiteblackipRule
Parameters of the createWhiteblackipRule Function
Function: Creates a blacklist or whitelist rule.
Table 21 Input parameters of the createWhiteblackipRule function
Parameter Type
Mandatory
policy_id
String
Yes
name
String
Rule name. The value can contain 1 to 256 characters.
Yes
addr
String
IP address or IP address ranges, for example, 42.123.120.66 or 42.123.120.0/16. Either addr** or **ip_group_id must be specified. If both are specified, addr takes precedence.
No
white
Integer
Protective action. The options are 0, 1, and 2. 0: The service blocks attacks. 1: The service allows requests. 2: The service only logs requests.
Yes
description
String
Description of the blacklist or whitelist rule.
Yes
ipGroupId
String
IP address group ID. You can query the ID on the Objects > Address Groups page on the console. Either addr** or **ip_group_id must be specified. If both are specified, addr takes precedence.
No
enterpriseProjectId
String
No
punishmentId
String
Known attack source rule ID.
No
agency_type
String
No
Table 22 Output parameters of the createWhiteblackipRule function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the createWhiteblackipRule Function
  "headers": {
  "code": 200,
  "body": {
    "id": "rule-12345678",
    "name": "test-rule",
    "policy_id": "policy-12345678",
    "addr": "192.168.1.1",
    "white": 1,
    "description": "Test the blacklist or whitelist rule.",
    "status": 1
Plugin Execution Function deleteWhiteblackipRule
Parameters of the deleteWhiteblackipRule Function
Function: Deletes a blacklist or whitelist rule.
Table 23 Input parameters of the deleteWhiteblackipRule function
Parameter Type
Mandatory
policy_id
String
Yes
rule_id
String
Blacklist or whitelist rule ID.
Yes
String
No
agency_type
String
No
Table 24 Output parameters of the deleteWhiteblackipRule function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the deleteWhiteblackipRule Function
  "headers": {
  "code": 200,
  "body": {}
Plugin Execution Function updateWhiteblackipRule
Parameters of the updateWhiteblackipRule Function
Function: Updates a blacklist or whitelist rule.
Table 25 Input parameters of the updateWhiteblackipRule function
Parameter Type
Mandatory
policyId
String
Yes
ruleId
String
Yes
name
String
Rule name.
Yes
addr
String
IP address or IP address range.
Yes
white
Integer
Yes
description
String
Yes
enterpriseProjectId
String
No
agency_type
String
No
Table 26 Output parameters of the updateWhiteblackipRule function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the updateWhiteblackipRule Function
  "headers": {
  "code": 200,
  "body": {
    "name": "updated-rule",
    "addr": "192.168.1.2",
    "white": 0,
    "description": "Updated blacklist or whitelist rule",
    "status": 1
Plugin Execution Function listWhiteblackipRule
Parameters of the listWhiteblackipRule Function
Function: Queries the blacklist or whitelist rule list.
Table 27 Input parameters of the listWhiteblackipRule function
Parameter Type
Mandatory
policy_id
String
Yes
page
Integer
No
pagesize
Integer
No
name
String
Blacklist or whitelist rule name.
No
addr
String
IP address or IP address range in the blacklist or whitelist rule.
No
String
No
resultVariable
String
Query result filter.
No
Table 28 Output parameters of the listWhiteblackipRule function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listWhiteblackipRule Function
  "headers": {
  "code": 200,
  "body": {
    "total": 10,
    "items": [
        "white": 1,
        "description": "Test blacklist or whitelist rule"
Plugin Execution Function listHost
Parameters of the listHost Function
Function: Queries the list of protected domain names.
Table 29 Input parameters of the listHost function
Parameter Type
Mandatory
String
No
page
Integer
No
pagesize
Integer
No
hostname
String
Protected domain name.
No
policyname
String
Policy name.
No
Table 30 Output parameters of the listHost function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listHost Function
  "headers": {
  "code": 200,
  "body": {
    "total": 10,
    "items": [
        "id": "host-12345678",
        "hostname": "www.example.com",
        "policy_name": "test-policy",
        "protect_status": 1,
        "access_status": 1
Plugin Execution Function listCompositeHosts
Parameters of the listCompositeHosts Function
Function: Queries the list of domain names and returns the formatted domain name protection status.
Table 31 Input parameters of the listCompositeHosts function
Parameter Type
Mandatory
hostname
String
No
page
Integer
No
limit
Integer
No
enterpriseProjectId
String
No
Table 32 Output parameters of the listCompositeHosts function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listCompositeHosts Function
  "headers": {
  "code": 200,
  "body": {
    "total": 10,
    "items": [
        "protect_status": 1
Plugin Execution Function showBundle
Parameters of the showBundle Function
Function: Obtains WAF resource quota information.
Table 33 Input parameters of the showBundle function
Parameter Type
Mandatory
enterpriseProjectId
string
No
resultVariable
String
No
Table 34 Output parameters of the showBundle function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the showBundle Function
  "headers": {
  "code": 200,
  "body": {
    "bundleId": "bundle-12345678",
    "name": "WAF package,"
    "quota": 100
Plugin Execution Function showSourceIp
Parameters of the showSourceIp Function
Function: Obtains the WAF source IP address configuration.
Table 35 Input parameters of the showSourceIp function
Parameter Type
Mandatory
input
String
Input parameter.
No
Table 36 Output parameters of the showSourceIp function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the showSourceIp Function
  "headers": {
  "code": 200,
  "body": {
    "source_ips": [
      "192.168.1.1",
      "192.168.1.2"
Plugin Execution Function showSubscriptionInfo
Parameters of the showSubscriptionInfo Function
Function: Obtains WAF subscription information.
Table 37 Input parameters of the showSubscriptionInfo function
Parameter Type
Mandatory
input
String
Input parameter.
No
Table 38 Output parameters of the showSubscriptionInfo function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the showSubscriptionInfo Function
  "headers": {
  "code": 200,
  "body": {
    "subscriptionId": "sub-12345678",
    "subscriptionName": "WAF subscription,"
    "status": "ACTIVE",
    "version": "v1.0"
Plugin Execution Function operationAddressGroup
Parameters of the operationAddressGroup Function
Function: Manages address groups in batches. You can add or delete IP addresses to or from a WAF address group.
Table 39 Input parameters of the operationAddressGroup function
Parameter Type
Mandatory
ip_list
String
IP address list.
Yes
String
Yes
policy
String
Policy name.
Yes
operation_type
String
Operation type. SENDING: adding IP addresses. DELETING: deleting IP addresses.
Yes
language
String
Language. The value can be zh-cn or en-us. Uppercase letters and other values are not supported.
zh-cn: simplified Chinese. en-us: English.
No
agency_type
String
No
Table 40 Output parameters of the operationAddressGroup function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the operationAddressGroup Function
  "headers": {
  "code": 200,
  "body": {
    "ips": "192.168.1.1,192.168.1.2,192.168.1.3",
    "size": 3
