Updated on 2026-09-14 GMT+08:00
HSS
Function Description
This plugin is built into SecMaster and calls Host Security Service (HSS) APIs to perform operations. It is mainly used to manage HSS resources such as the status, vulnerabilities, and security incidents related to servers.
Each built-in plugin has a corresponding built-in operation connection.
Viewing Details and Operation Connections of the HSS Plugin
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Security Orchestration > Plugins.
    Figure 2 Plugins page
  5. On the Plugins page, select the HSS plugin under the Huawei Cloud catalog. The Details tab is displayed by default. The Details tab displays the login credential information of the operation connection associated with the plugin.
  6. Click the Operation Connections tab for the HSS plugin. On the displayed page, you can view information about the operation connections associated with the plugin.
  7. For details about how to edit or delete an operation connection, see Editing an Operation Connection and Deleting an Operation Connection. For details about how to add an operation connection for a plugin, see Creating an Operation Connection. A plugin can have multiple operation connections.
Plugin Execution Function listHostStatus
Parameters of the listHostStatus Function
Function: Calls HSS APIs to list server status information. A large number of filtering parameters are supported.
Table 1 Input parameters of the listHostStatus function
Parameter Type
Parameter Description
Mandatory
host_id
string
Server ID.
No
offset
string
Offset.
No
limit
string
Number of records on each page.
No
enterprise_project_id
string
Enterprise project ID.
No
agent_status
string
Agent status.
No
host_name
string
Server name.
No
host_status
string
Server status: ACTIVE (running), SHUTOFF (stopped), BUILDING (creating), or ERROR (faulty).
No
os_type
string
OS type. The value can be Linux or Windows.
No
private_ip
string
Private IP address.
No
public_ip
string
Public IP address.
No
detect_result
string
Cloud server security scan result.
No
ip_addr
string
Public or private IP address.
No
protect_status
string
Protection status.
No
group_id
string
Server group ID.
No
group_name
string
Server group name.
No
vpc_id
string
VPC ID
No
has_intrusion
string
Whether there are alerts.
No
has_vul
string
Whether there are vulnerabilities.
No
has_baseline
string
Whether there are baseline risks.
No
sort_key
string
Key value used for sorting. Currently, data can only be sorted by recent_scan_time, and the value of sort_dir determines whether to sort the data in ascending or descending order.
No
sort_dir
string
Sorting order. The default order is descending. If sort_key is set to recent_scan_time, this parameter determines the sorting order. If sort_key is set to other values, data is sorted in descending order.
No
policy_group_id
string
Policy group ID.
No
policy_group_name
string
Policy group name.
No
charging_mode
string
Billing mode. packet_cycle: yearly/monthly billing. on_demand: pay-per-use billing
No
refresh
string
Whether to forcibly synchronize servers from ECS.
No
get_common_login_locations
string
Whether to obtain the common login locations of a server. The value can be true or false.
No
above_version
string
Whether to return all versions later than the current version.
No
outside_host
string
Whether a server is a Huawei Cloud server.
No
asset_value
string
Asset importance. Its value can be:
  • important
  • common
  • test
No
label
string
Label.
No
server_group
string
List of server groups to which tasks are delivered.
No
agent_upgradable
string
Whether the agent is upgradable.
No
install_mode
string
Whether the installation mode is enabled.
No
binding_key
string
Whether a DEW key is bound.
No
protect_interrupt
string
Directory where honeypot protection failed. (This parameter has a value only if certain honeypots failed to be deployed.)
No
incluster
string
Whether a node is in a cluster.
No
protect_degradation
string
Protection degradation.
No
cluster_id
string
Cluster ID.
No
resultVariable
Object
Output parameter filtering parameter. Format: {"New field name 1": "$ (Original parameters returned).xxx (Next level of the returned parameters) or {xxx1, xxx2}", {"New field name 2": ...}, ...}, for example, {"alert_id": "$.body.data.id"} or {"alert": "$.body.data{id,name}"}.
No
Table 2 Output parameters of the listHostStatus function
Parameter Type
headers
Object
Headers of the response returned by the HSS API. It includes basic request and response information, such as the request time, response service, and request ID.
code
Int
Status code, which indicates whether the request is successful.
Response code description:
  • If the value of code is 200, the request is successful.
  • If the value of code is 401, the account or password is incorrect.
  • If the value of code is 403, the permission is insufficient.
  • If the value of code is 404, the requested resource does not exist.
body
Object
Content returned by the API.
Output Example of the ListHostStatus Function
  "headers": {
    "Transfer-Encoding": "chunked",
    "Server": "api-gateway",
    "X-Request-Id": "86c1a4653fadf6cc0ab4acc6baed323d",
    "X-Content-Type-Options": "nosniff",
    "Connection": "keep-alive",
    "X-Download-Options": "noopen",
    "Date": "Mon, 25 May 2026 07:52:28 GMT",
    "X-Frame-Options": "SAMEORIGIN",
    "Strict-Transport-Security": "max-age=31536000; includeSubdomains;",
    "Cache-Control": "no-cache, no-store, max-age=0, must-revalidate",
    "Set-Cookie": "JSESSIONID=7A398C2C40223D1A28FB712C87A95C40; Path=/hss; Secure; HttpOnly",
    "X-XSS-Protection": "1; mode=block;",
    "Content-Type": "application/json; charset=UTF-8"
  "code": 200,
  "body": {
    "data_list": [
        "host_sources": "ecs",
        "agent_update_time": 1776670824120,
        "public_ip": "124.71.xxx.0",
        "agent_id": "ed8bafxxx938a69306f3b44ae69812xxxxx17481639ea159cd1845805c700",
        "charging_mode": "packet_cycle",
        "enterprise_project_name": "default",
        "vpc_id": "315xxxf2-a174-4ddc-bcc0-e44xxxxe1f3",
        "open_time": 1776670861034,
        "auto_open_version": "hss,hss-pc,ces",
        "private_ip": "192.xxx.21.153",
        "policy_group_id": "fe192900-d3e6-4a86-ab28-501xxxxa38949",
        "mode": "default",
        "upgradable": false,
        "agent_status": "online",
        "ransom_protection_status": "opened",
        "os_bit": "64",
        "protect_interrupt": false,
        "protect_status": "opened",
        "two_factor_auth": false,
        "outside_host": false,
        "detect_result": "risk",
        "os_version": "10.0.2xxx8.2",
        "service_provider_name": "",
        "vulnerability": 3,
        "baseline": 7,
        "wtp_protect_status": "closed",
        "host_status": "ACTIVE",
        "version": "hss.version.premium",
        "host_id": "eda720c2-e690-42f5-be13-b12xxxx9900",
        "policy_group_name": "tenant_windows_premium_default_policy_group(default)",
        "agent_version": "4.0.34",
        "enterprise_project_id": "0",
        "intrusion": 10,
        "kernel_version": "10.0.2xxx48.2",
        "os_type": "Windows",
        "asset_value": "common",
        "container_type": 0,
        "os_name": "Windows Server 2022",
        "resource_id": "d4758bae-16cd-4c2d-bd5b-8cxxxx43640",
        "asset": 0,
        "agent_create_time": 1776670725830,
        "host_name": "ecs-495011-attack-defense test"
    "total_num": 1
Plugin Execution Function changeVulStatus
Parameters of the changeVulStatus Function
Function: Calls the corresponding HSS API to change the vulnerability status. This API allows you to ignore or unignore a vulnerability.
Table 3 Input parameters of the changeVulStatus function
Parameter Type
Mandatory
operateType
String
Operation type. The options are as follows:
  • ignore: The risk can be ignored.
  • not_ignore: Unignore the risk.
  • immediate_repair: Fix the risk immediately.
  • manual_repair: The risk can be manually repaired.
  • verify: Verify the fix.
Yes
vulID
String
Vulnerability ID.
Yes
hostIdList
String
Server ID list, which is the list of servers to be operated.
Yes
agency_type
String
Unified adaptation parameter for multiple accounts. Use the default value.
No
Table 4 Output parameters of the changeVulStatus function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the changeVulStatus Function
  "headers": {
    "X-Request-Id": "101a8a4a46892d9ad8e284805333a8b7",
    "Date": "Wed, 29 Apr 2026 09:30:12 GMT",
    "Set-Cookie": "JSESSIONID=5E4B3254xxxxE1965F2D6422ACD; Path=/hss; Secure; HttpOnly",
    "Vary": "Origin, Access-Control-Request-Method, Access-Control-Request-Headers",
    "Content-Type": "application/json; charset=utf-8"
  "code": 200,
  "body": {}
Plugin Execution Function listVulnerabilities
Parameters of the listVulnerabilities Function
Function: Calls the corresponding HSS API to list vulnerability information.
Table 5 Input parameters of the listVulnerabilities function
Parameter Type
Mandatory
type
String
Vulnerability type.
No
vulID
String
Vulnerability ID.
No
limit
String
Number of records displayed on each page. The value ranges from 10 to 200.
No
page
String
Page number for the query.
No
string
Enterprise project ID, which is used to filter assets in different enterprise projects. To query all enterprise projects, specify the all_granted_eps parameter.
No
vul_name
string
Vulnerability name. The value can contain 0 to 256 characters.
No
repair_priority
string
Vulnerability fixing priority. Options: Critical, High, Medium, and Low.
No
handle_status
string
Vulnerability handling status. Options: unhandled and handled.
No
label_list
string
Vulnerability tag. The value can contain 0 to 128 characters.
No
status
string
Vulnerability statuses:
  • vul_status_unfix: unhandled
  • vul_status_ignored: ignored
  • vul_status_verified: verifying
  • vul_status_fixing: fixing
  • vul_status_fixed: fixed
  • vul_status_reboot: fixed and pending restart
  • vul_status_failed: fix failed
  • vul_status_fix_after_reboot: Restart the server and try again.
No
asset_value
string
Importance of the vulnerable host. Value range: important, common, and test.
No
group_name
string
Name of the server group to which the vulnerable host belongs. The value is a string of 0 to 256 characters.
No
Table 6 Output parameters of the listVulnerabilities function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listVulnerabilities Function
  "headers": {
    "X-Request-Id": "030d5594846a7c3786652c7fbbbc9e9a",
    "Set-Cookie": "JSESSIONID=55FA148134245FC5BC7355B31A794479; Path=/hss; Secure; HttpOnly",
  "code": 200,
  "body": {
    "data_list": [
        "vul_name": "HCE2-SA-2026-0047 An update for libarchive is now available for HCE 2.0",
        "label_list": [
          "Exploit Disclosed",
          "Exploited In The Wild",
          "POC Disclosed"
        "description": "Security Fix(es): An issue was discovered in libarchive bsdtar before version 3.8.1 in function apply_substitution in file tar/subst.c when processing crafted -s substitution rules. This can cause unbounded memory allocation and lead to denial of service (Out-of-Memory crash). (CVE-2025-60753)",
        "type": "linux_vul",
        "severity_level": "Medium",
        "solution_detail": "To upgrade the affected software",
        "url": "https://repo.huaweicloud.com/hce/2.0/sa/HCE2-SA-2026-0047.xml",
        "unhandle_host_num": 2,
        "host_id_list": [
          "d27f2d2e-5b35-4228-9533-7axxxxf893",
          "eddc1821-fd72-49e3-a59d-xxxxea",
          "0f4e55e3-2bdf-4224-952b-8axxxxxb4a0a"
        "cve_list": [
            "cve_id": "CVE-2025-60753",
            "cvss": 5.5
        "repair_priority": "Medium",
        "vul_id": "HCE2-SA-2026-0047",
        "repair_priority_list": [
            "repair_priority": "Critical",
            "host_num": 0
            "repair_priority": "High",
            "host_num": 0
            "host_num": 3
            "repair_priority": "Low",
            "host_num": 0
        "host_num": 3,
        "repair_necessity": "Medium",
        "scan_time": 1777454641685,
        "max_cvss_score": 5.5,
        "hosts_num": {
          "important": 0,
          "common": 3,
          "test": 0
    "total_num": 1
Plugin Execution Function listEvents
Parameters of the listEvents Function
Function: Calls the corresponding HSS API to list security incidents.
Table 7 Input parameters of the listEvents function
Parameter Type
Mandatory
region
string
Region.
Yes
category
string
Incident category. The value can be attack, illegal, or vulnerability.
Yes
Table 8 Output parameters of the listEvents function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listEvents Function
  "headers": {
    "X-Request-Id": "67c9d44e053cbab6a18a71256f3d4bbd",
    "Date": "Wed, 29 Apr 2026 06:43:08 GMT",
    "Set-Cookie": "JSESSIONID=8ABA80B620119E44C607C2BE421C2556; Path=/hss; Secure; HttpOnly",
  "code": 200,
  "body": {
    "data_list": [
        "handle_time": 1777443489307,
        "handler": "System",
        "public_ip": "100.93.XX.83",
        "event_count": 1,
        "recommendation": "For mining software alarm events, the following suggestions are provided:\r\n1. After receiving an alarm, check whether the related file or process is normal. If yes, select the corresponding alarm event, click Handle, and select Ignore or Add to Alarm Trustlist.\r\n2. After receiving an alarm, check whether the file or process is normal. If the file or process is malicious, select the alarm event, click Handle, and select Isolate and Kill or manually clean the virus.\r\n3. If malicious programs cause data loss and you have enabled the CBR service, you can restore data from the CBR service backup.\r\n4. To prevent further intrusion, you can fix vulnerabilities on the Vulnerability Management page of HSS Risk Prevention.",
        "description": "After hackers intrude, mining programs are implanted to earn profits. Such programs occupy CPU resources, affecting normal services of users and causing great harm. In addition, the program may also have a self-deleting behavior, or disguised as a system program to evade detection.\r\n\r\n",
        "private_ip": "192.xx8.0.246",
        "event_abstract": "The suspected mining software exists on host test-a00607964. The confidence value is Medium, the file path is /opt/Auto_test/test/sample/Virus + Malware + Trojan + Backdoor + Worm + Cryptojacking + Hacker/Cryptojacking software /Xmrig-mining-virus-samples-master/newinit.sh\n"
        "event_type": 1016,
        "occur_time": 1777443470000,
        "operate_accept_list": [
          "do_not_isolate_or_kill"
        "att_ck": "Impact",
        "event_details": "{\"\"Confidence\"\":\"\"90\"\",\"\"Trust Level\"\":\"\"Malicious\"\",\"\"Virus Type\"\":\"\"Linux.Miner.Coinminer\"\",\"\"Malware Family\"\":\"\"Linux.Miner.Coinminer\"\",\"\"file info\"\": [{\"\"File Hash\"\":\"\"196b528e7c816ef6dc101e193bb73338e2e6c696137302f991099682e52bc910\"\",\"\"File SHA-256\"\":\"\"196b528e7c816ef6dc101e193bb73338e2e6c696137302f991099682e52bc910\"\",\"\"File Path\"\":\"\"/opt/Auto_test/test/sample/Virus + Malware + Trojan + Backdoor + Worm + Cryptojacking + Hacker/Cryptojacking software/Xmrig-mining-virus-samples-master/newinit.sh\"\"} ], \"\"Virus Name\"\":\"\"Linux.Miner.Coinminer\"\"}",
        "handle_status": "handled",
        "recent_time": 1777443470000,
        "severity": "Critical",
        "resource_info": {
          "host_ip": "192.xxx.0.246",
          "public_ip": "100.xx.12.83",
          "os_version": "2.0",
          "host_id": "d27f2d2e-5b35-4228-9533-7axxxxf893",
          "agent_version": "3.2.31.B010",
          "vm_uuid": "d27f2d2e-5b35-4228-9533-7adxxxx7f893",
          "project_id": "f69081793d9e4exxxx79dcef961989",
          "os_type": "Linux",
          "os_name": "HCE",
          "region_name": "cn-north-7",
          "cloud_id": "",
          "host_name": "test-axxx964",
          "vm_name": "test-axxx7964"
        "file_info_list": [
            "file_path": "/opt/Auto_test/test/sample/Virus + Malware + Trojan + Backdoor + Worm + Cryptojacking + Hacker/Cryptojacking software /Xmrig-mining-virus-samples-master/newinit.sh",
            "file_hash": "196b528e7c816ef6dc101e193bb73338xxxx37302f991099682e52bc910",
            "file_sha256": "196b528e7c816ef6dc101e193bb7333xxxxx37302f991099682e52bc910"
        "confidence": 90,
        "attack_phase": "actions",
        "operate_detail_list": [
            "agent_id": "13b6130f9cdcb12de8951593eb111axxxf8a61158f7ace46aea76",
            "is_parent": false
        "malware_info": {
          "severity": 4,
          "detect_module": "av_det",
          "detect_type": "disk_scan",
          "event_detail": "{\"engineResultList\":[{\"detect_engine\":\"AV_03_A\",\"malware_class\":2},{\"detect_engine\":\"AV_02_CDE\",\"malware_class\":2}]}",
          "event_type": "Linux.Miner.Coinminer",
          "file_hash": "196b528e7c816ef6dc101e193bb73338xxxxxx37302f991099682e52bc910",
          "event_name": "Linux.Miner.Coinminer",
          "module_name": "agentEventAv",
          "malware_class": "malware",
          "detect_time": 1752568327697,
          "recent_time": 1752568327697,
          "malware_family": "Linux.Miner.Coinminer"
        "host_id": "d27f2d2e-5b35-4228-9533-7adxxx893",
        "handle_method": "isolate_and_kill",
        "event_id": "261cab5c-4393-11f1-96a5-fa163e1e766c",
        "event_class_id": "av_1016",
        "os_type": "Linux",
        "attack_tag": "collapsible_host",
        "event_name": "Mining",
    "total_num": 1
Plugin Execution Function handEvent
Parameters of the handEvent Function
Function: Calls the corresponding HSS API to handle security incidents.
Table 9 Input parameters of the handEvent function
Parameter Type
Mandatory
operateType
string
Operation type.
Yes
handler
string
Handler.
Yes
eventClassID
string
Incident category ID.
Yes
eventID
string
Incident ID.
Yes
occurTime
string
Occurrence time.
Yes
eventType
string
Incident type.
Yes
operateDetailList
string
Operation details list, in JSON format.
Yes
agency_type
string
No
Table 10 Output parameters of the handEvent function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the handEvent Function
  "headers": {
    "X-Request-Id": "2f1a90568708dd70223922bf7e045272",
    "Date": "Fri, 24 Apr 2026 01:38:18 GMT",
    "Set-Cookie": "JSESSIONID=C3BC36608xxxx80C9C1A2CF7A4; Path=/hss; Secure; HttpOnly",
  "code": 200,
  "body": {}
Plugin Execution Function listSecurityEvents
Parameters of the listSecurityEvents Function
Function: Calls the corresponding HSS API to list security incident details.
Table 11 Input parameters of the listSecurityEvents function
Parameter Type
Mandatory
offset
string
Offset.
No
limit
string
No
eventId
string
Incident ID.
No
region
string
Region ID.
Yes
enterpriseProjectId
string
No
lastDays
string
Number of recent days for the query.
No
hostName
string
Server name.
No
hostId
string
Server ID.
No
privateIp
string
Private IP address of the host.
No
containerName
string
Container name.
No
eventTypes
string
List of incident types.
No
handleStatus
string
Handling status. Options: unhandled and handled.
No
severity
string
Severity. Options: security, low, medium, high, and critical.
No
category
string
Yes
beginTime
string
Query start time. The value is a timestamp, in milliseconds.
No
endTime
string
Query end time. The value is a timestamp, in milliseconds.
No
eventClassIds
string
Incident category ID list. Multiple IDs must be separated by commas (,).
No
Table 12 Output parameters of the listSecurityEvents function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listSecurityEvents Function
  "headers": {
  "code": 200,
  "body": {
    "data_list": [
        "event_count": 1,
        "event_type": 1016,
        "att_ck": "Impact",
        "resource_info": {
          "host_ip": "192.xx8.0.246",
          "public_ip": "100.93.12.83",
          "host_id": "d27f2d2e-5b35-4228-9533-7axxxx893",
          "vm_uuid": "d27f2d2e-5b35-4228-9533-7ad2cxxx93",
          "project_id": "f69081793d9e4ea8a2f4xxxx961989",
          "os_type": "Linux",
          "os_name": "HCE",
          "cloud_id": "",
          "host_name": "test-axxxx64",
          "vm_name": "test-a0xxxx64"
        "file_info_list": [
            "file_hash": "196b528e7c816ef6dc101e193bb73338e2e6c696137302f991099682e52bc910",
            "file_sha256": "196b528e7c816ef6dc101e193bb73338e2e6c696137302f991099682e52bc910"
        "confidence": 90,
            "agent_id": "13b6130f9cdcb12de8951593eb111ab37e2812e30ef4f8a61158f7ace46aea76",
            "is_parent": false
        "malware_info": {
          "severity": 4,
          "file_hash": "196b528e7c816ef6dc101e193bb7xxxxx9682e52bc910",
        "host_id": "d27f2d2e-5b35-4228-9533-7ad2xxxx893",
        "os_type": "Linux",
        "host_name": "test-a00607964"
    "total_num": 1
Plugin Execution Function changeEvent
Parameters of the changeEvent Function
Function: Calls the corresponding HSS API to change the security incident information or status.
Table 13 Input parameters of the changeEvent function
Parameter Type
Mandatory
region
string
Region ID.
Yes
enterpriseProjectId
string
No
containerName
string
Container name.
No
containerId
string
Container ID.
No
operateType
string
Operation type. The value can be ignore, not_ignore, block_ip, unblock_ip, isolate_file, or restore_file.
No
handler
string
Handler account.
No
eventClassId
string
Yes
eventId
string
Incident ID.
Yes
eventType
string
Incident type. The value is an integer.
Yes
occurTime
string
Time when the incident occurred. The value is a timestamp, in milliseconds.
Yes
operateDetailList
string
Yes
eventWhiteRuleList
string
Incident whitelist rules, in JSON format.
Yes
agency_type
string
No
Table 14 Output parameters of the changeEvent function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the changeEvent Function
  "headers": {
    "Set-Cookie": "JSESSIONID=C3BC366082E2857DxxxxxxxCF7A4; Path=/hss; Secure; HttpOnly",
  "code": 200,
  "body": {}
Plugin Execution Function getVirus
Parameters of the getVirus Function
Function: Calls the corresponding HSS API to obtain virus or malware information.
Table 15 Input parameters of the getVirus function
Parameter Type
Mandatory
enterpriseProjectId
String
Enterprise project ID. To query all enterprise projects, set this parameter to all_granted_eps.
No
Table 16 Output parameters of the getVirus function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the getVirus Function
  "headers": {
    "X-Request-Id": "b0c596ce0defd46122d7bf7d953a4634",
    "Date": "Mon, 25 May 2026 08:41:54 GMT",
    "Set-Cookie": "JSESSIONID=4F8F5DFE5FC0xxxxxxxx6992464B; Path=/hss; Secure; HttpOnly",
  "code": 200,
  "body": {
    "enabled": true
Plugin Execution Function killVirus
Parameters of the killVirus Function
Function: Calls the corresponding HSS API to enable or disable the virus scan function.
Table 17 Input parameters of the killVirus function
Parameter Type
Mandatory
enterpriseProjectId
string
Yes
enabled
string
Whether to enable virus scan. The value can be true (enabled) or false (disabled).
Yes
agency_type
string
No
Table 18 Output parameters of the killVirus function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the killVirus Function
  "headers": {
    "X-Request-Id": "68e1221569967b3906c1b19cba30d655",
    "Date": "Mon, 25 May 2026 08:49:08 GMT",
    "Set-Cookie": "JSESSIONID=4681056F655D7B7FC9F62DA11A7B0FCA; Path=/hss; Secure; HttpOnly",
  "code": 200,
  "body": {}
Plugin Execution Function createVulnerabilityScanTask
Parameters of the createVulnerabilityScanTask Function
Function: Calls the corresponding HSS API to create a vulnerability scan task.
Table 19 Input parameters of the createVulnerabilityScanTask function
Parameter Type
Mandatory
manualScanType
string
Manual scan type. The value can be vul_scan (vulnerability scan) or baseline_scan (baseline scan).
Yes
batchFlag
string
Whether to perform batch scanning. The value can be true (batch) or false (single).
Yes
rangeType
string
Scan scope type. The value can be all_host (all hosts) or specific_host (specified hosts).
Yes
agentIdList
string
Agent ID list. This parameter is mandatory when rangeType is set to specific_host.
No
urgentVulIdList
string
Critical vulnerability ID list.
No
agency_type
string
No
Table 20 Output parameters of the createVulnerabilityScanTask function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the createVulnerabilityScanTask Function
  "headers": {
  "code": 200,
  "body": {
    "task_id": "d8a12cf7-6a43-4cd6-92b4-aabf1e917"
Plugin Execution Function listContainerNodes
Parameters of the listContainerNodes Function
Function: Calls the corresponding HSS API to list container nodes.
Table 21 Input parameters of the listContainerNodes function
Parameter Type
Mandatory
offset
string
Offset.
No
region
string
Region ID.
No
enterpriseProjectId
string
No
limit
string
No
hostName
string
Server name.
No
agentStatus
string
Agent status. The value can be installed, not_installed, online, or offline.
No
protectStatus
string
Protection status. The value can be closed, opened, or protection_exception.
No
containerTags
string
Container label.
No
resultVariable
Object
No
language
string
Response language of the query result. The value can be zh-cn or en-us. Uppercase letters and other values are not supported.
The value zh-cn indicates that the query result is displayed in simplified Chinese, and the value en-us indicates that the query result is displayed in English.
No
Table 22 Output parameters of the listContainerNodes function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listContainerNodes Function
  "headers": {
    "X-Request-Id": "d7650f84626f019a9a5aac61a5b2c83a",
    "Date": "Mon, 25 May 2026 08:57:56 GMT",
    "Set-Cookie": "JSESSIONID=FFA239FBB538B85123AF8E52B04EFF41; Path=/hss; Secure; HttpOnly",
  "code": 200,
  "body": {
    "data_list": [
        "public_ip": "xx1.36.76.xx9",
        "agent_id": "ce88298ff7ecXXXXXXXXX71824b06711d8b2fd7854a5cc288175785f188cf9dc0",
        "group_name": "Container (all Projects)",
        "detect_result": "undetected",
        "is_container_node": true,
        "auto_open_version": "hss",
        "host_id": "005e54ce-736a-436b-b7fb-8xxxxx53fb7",
        "private_ip": "192.168.0.197",
        "policy_group_id": "20210330-1430-1001-1002-10xxx0000",
        "policy_group_name": "default_policy_group",
        "container_tags": "other",
        "os_type": "Linux",
        "os_name": "EulerOS",
        "protect_status": "closed",
        "host_name": "ecs-poc-test",
        "is_trial_quota": false
    "total_num": 1
Plugin Execution Function listRansomwareProtectionNodes
Parameters of the listRansomwareProtectionNodes Function
Function: Calls the corresponding HSS API to list ransomware protection nodes.
Table 23 Input parameters of the listRansomwareProtectionNodes function
Parameter Type
Mandatory
offset
string
Offset.
Yes
string
No
limit
string
Yes
host_name
string
Server name.
No
host_id
string
Server ID.
No
os_type
string
No
host_ip
string
Host IP address.
No
private_ip
string
Private IP address.
No
host_status
string
No
string
Ransomware protection status. The value can be closed (disabled), opened (being protected), opening (being enabled), closing (being disabled), protect_failed (protection failed), or protect_degraded (protection degraded)
No
protect_policy_name
string
Defense policy name.
No
policy_name
string
Policy name.
No
policy_id
string
Policy ID.
No
agent_status
string
Agent status.
No
group_id
string
Server group ID.
No
group_name
string
Server group name.
No
last_days
string
Number of latest days for the query.
No
resultVariable
Object
No
Table 24 Output parameters of the listRansomwareProtectionNodes function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listRansomwareProtectionNodes Function
  "headers": {
    "X-Request-Id": "e3134584c0b749600c51b34ebf6679d6",
    "Date": "Mon, 25 May 2026 09:01:14 GMT",
    "Set-Cookie": "JSESSIONID=865A9AA9FD1B33DE8722444EC76E6485; Path=/hss; Secure; HttpOnly",
  "code": 200,
  "body": {
    "data_list": [
        "host_ip": "124.71.228.0",
        "backup_policy_enabled": false,
        "protect_policy_id": "dc32b365-97d7-308a-8923-52axxxxxx93",
        "agent_id": "ed8bafe11a1938a69306f3b44ae69812a21fb51xxxxxxd1845805c700",
        "backup_error": {
          "error_code": 0
        "count_protect_event": 0,
        "host_id": "eda720c2-e690-42f5-be13-xxxx9900",
        "project_id": "099706f40xxxx014b68c0527",
        "host_source": "ecs",
        "protect_policy_name": "tenant_windows_anti_default_policy(default)",
        "backup_protection_status": "closed",
    "total_num": 1
Plugin Execution Function listWtpProtectHost
Parameters of the listWtpProtectHost Function
Function: Calls the corresponding HSS API to list hosts with web tamper protection enabled.
Table 25 Input parameters of the listWtpProtectHost function
Parameter Type
Mandatory
offset
string
Offset.
No
string
No
limit
string
No
host_name
string
Server name.
No
host_id
string
Server ID.
No
os_type
string
No
private_ip
string
Private IP address.
No
public_ip
string
Public IP address.
No
agent_status
string
Agent status.
No
wtp_status
string
Web tamper protection status. The value can be closed (disabled), opened (protected), opening (enabling), closing (disabling), or open_failed (protection failed).
No
group_name
string
Server group name.
No
protect_status
string
Protection status.
No
resultVariable
string
No
Table 26 Output parameters of the listWtpProtectHost function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listWtpProtectHost Function
  "headers": {
    "X-Request-Id": "8aa7f8b7e7197ca198d1037600d3ecfb",
    "Date": "Mon, 25 May 2026 09:03:22 GMT",
    "Set-Cookie": "JSESSIONID=0CD5CA1XXXXXXXX6AB301168CA3A1B; Path=/hss; Secure; HttpOnly",
  "code": 200,
  "body": {
    "data_list": [],
    "total_num": 0
Plugin Execution Function listOtherVulnerabilities
Parameters of the listOtherVulnerabilities Function
Function: Calls the corresponding HSS API to list other types of vulnerabilities.
Table 27 Input parameters of the listOtherVulnerabilities function
Parameter Type
Mandatory
projectId
String
Project ID.
No
domainId
String
Tenant ID.
No
type
String
Vulnerability type.
No
vulID
String
Vulnerability ID.
No
limit
String
No
page
String
Offset. It specifies the starting position from which records are returned.
No
Table 28 Output parameters of the listOtherVulnerabilities function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the listOtherVulnerabilities Function
  "headers": {
    "Set-Cookie": "JSESSIONID=55FA148134XXXXXXXXX794479; Path=/hss; Secure; HttpOnly",
  "code": 200,
  "body": {
    "data_list": [
        "label_list": [
          "POC Disclosed"
        "host_id_list": [
          "d27f2d2e-5b35-4228-9533-7adxxxxxf893",
          "eddc1821-fd72-49e3-a59d-26xxxxx8ea",
          "0f4e55e3-2bdf-4224-952b-8axxxxxx4a0a"
        "cve_list": [
            "cvss": 5.5
            "host_num": 0
            "host_num": 0
            "host_num": 3
            "host_num": 0
        "host_num": 3,
        "hosts_num": {
          "important": 0,
          "common": 3,
          "test": 0
    "total_num": 1
Plugin Execution Function changeOtherVulStatus
Parameters of the changeOtherVulStatus Function
Function: Calls the corresponding HSS API to change the status of other types of vulnerabilities.
Table 29 Input parameters of the changeOtherVulStatus function
Parameter Type
Mandatory
operateType
String
Handling operation type. The value can be ignore, not_ignore, immediate_repair, manual_repair, or verify.
Yes
vulID
String
Vulnerability ID.
Yes
hostIdList
String
List of IDs of servers to be operated.
Yes
projectId
String
Project ID.
No
domainId
String
Tenant ID.
No
agency_type
String
No
Table 30 Output parameters of the changeOtherVulStatus function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the changeOtherVulStatus Function
  "headers": {
    "Set-Cookie": "JSESSIONID=5E4B3254438AB3BCDE1965F2D6422ACD; Path=/hss; Secure; HttpOnly",
  "code": 200,
  "body": {}
Plugin Execution Function changeCheckRuleState
Parameters of the changeCheckRuleState Function
Function: Calls the corresponding HSS API to change the status of a check rule.
Table 31 Input parameters of the changeCheckRuleState function
Parameter Type
Mandatory
hostId
string
Server ID.
No
enterpriseProjectId
string
No
action
string
Operation action. The value can be ignore, not_ignore, immediate_repair, manual_repair, or verify.
Yes
checkName
string
Check item name.
Yes
checkRuleId
string
Check rule ID.
Yes
standard
string
Baseline standard. The value can be hw_standard, cis_standard, and custom_standard.
Yes
agency_type
string
No
Table 32 Output parameters of the changeCheckRuleState function
Parameter Type
headers
Object
code
Int
body
Object
Output Example of the changeCheckRuleState Function
   "headers": {
     "X-Request-Id": "f7e759ff25266227a1d31f5068a5b3ed",
     "Pragma": "no-cache",
     "Date": "Mon, 25 May 2026 09:10:00 GMT",
   "code": 200,
   "body": {}
