Help Center/
SecMaster/
User Guide/
Log Audit/
Query and Analysis Syntax - V2/
SecMaster SQL Syntax Reference/
Data Query Language (DQL) Syntax/
Deduplication
Updated on 2025-08-11 GMT+08:00
Deduplication
Function
Deduplication removes rows that duplicate over a set of columns, keeping only the first one or the last one.
Syntax Format
1 2 3 4 5 6 7 |
SELECT [column_list] FROM ( SELECT [column_list], ROW_NUMBER() OVER ([PARTITION BY col1[, col2...]] ORDER BY time_attr [asc|desc]) AS rownum FROM table_name) WHERE rownum = 1 |
Syntax Description
- ROW_NUMBER(): Assigns a unique, sequential number to each row, starting with one.
- PARTITION BY col1[, col2...]: specifies the column of the partition, for example, the key for deduplication.
- ORDER BY time_attr [asc|desc]: Specifies the ordering column, which must be a time attribute. Currently Flink supports proctime only. Ordering by ASC means to keep the first row, ordering by DESC means to keep the last row.
- WHERE rownum = 1: The rownum = 1 is required for Flink to recognize this query is deduplication.
Precautions
None
Example
The following examples show how to remove duplicate rows on order_id. The proctime is an event time attribute.
1 2 3 4 5 6 |
SELECT order_id, user, product, number FROM ( SELECT *, ROW_NUMBER() OVER (PARTITION BY order_id ORDER BY proctime ASC) as row_num FROM Orders) WHERE row_num = 1; |
Parent topic: Data Query Language (DQL) Syntax
