SELECT
SELECT
- Syntax Format
1 2 3 4 5 6
SELECT [ ALL | DISTINCT ] { * | projectItem [, projectItem ]* } FROM tableExpression [ WHERE booleanExpression ] [ GROUP BY { groupItem [, groupItem ]* } ] [ HAVING booleanExpression ]
- Syntax Description
SELECT is used to select data from a table.
ALL indicates that all results are returned.
DISTINCT indicates that the duplicated results are removed.
- Precautions
- The table to be queried must exist. Otherwise, an error is reported.
- WHERE is used to specify the search condition, which can be the arithmetic operator, relational operator, or logical operator.
- GROUP BY is used to specify the grouping field, which can be one or more multiple fields.
- Example
Select the order which contains more than 3 pieces of data.
SELECT * FROM Orders WHERE units > 3;
Queries a group of constant data.
SELECT 'Lily', 'male', 'student', 17;
DISTINCT
- Function
In a table, a column may contain multiple duplicate values. Sometimes, you may want to list only different values. The DISTINCT keyword is used to return only unique values.
- Syntax Format
1 2 3 4 5 6
- Example
Query all asset types and deduplicate data based on type.
SELECT DISTINCT type FROM security_resource;
WHERE
- Syntax Format
1 2 3
SELECT { * | projectItem [, projectItem ]* } FROM tableExpression [ WHERE booleanExpression ]
This clause is used to filter the query results using the WHERE clause.
- Precautions
- The to-be-queried table must exist.
- WHERE filters the records that do not meet the requirements.
- Operators
Operator
Queries logs with the value of a specific field equal to a given value.
Queries logs with the value of a specific field not equal to a given value.
Queries logs with the value of a specific field greater than a given value.
Queries logs with the value of a specific field less than a given value.
Queries logs with the value of a specific field equal to or greater than a given value.
Queries logs with the value of a specific field equal to or less than a given value.
IN ('value1', 'value2')
Queries logs with the value of a specific field set to value1 or value2.
BETWEEN value1 and value2
Queries logs with the value of a specific field within the range of value1 and value2.
LIKE
Queries logs with a fuzzy keyword, for example, like '%one%'. The percent sign (%) is a wildcard that can replace any character.
IS NULL
Queries logs with the value of a specific field set to NULL.
IS NOT NULL
Queries logs with the value of a specific field set to NOT NULL.
- Example
Search orders which contain more than 3 pieces and fewer than 10 pieces of data.
1 2
SELECT * FROM Orders WHERE units > 3 and units < 10;
IN Operator
- Syntax Format
1 2 3
SELECT [ ALL | DISTINCT ] { * | projectItem [, projectItem ]* } FROM tableExpression WHERE column_name IN (value (, value)* ) | query
The IN operator allows multiple values to be specified in the WHERE clause. It returns true if the expression exists in the given table subquery.
- Precautions
The subquery table must consist of a single column, and the data type of the column must be the same as that of the expression.
- Example
Return user and amount information of the products in NewProducts of the Orders table.
1 2 3 4 5
SELECT user, amount FROM Orders WHERE product IN ( SELECT product FROM NewProducts );
