Overview
Background
A vulnerability is a flaw or weakness in an operating system, security policy, or software. Attackers may exploit these defects or weaknesses to compromise systems, steal data, interrupt services, or cause other security incidents. SecMaster can integrate vulnerability scan results from Host Security Service (HSS) and vulnerability data you import into SecMaster, so that you can quickly locate vulnerable assets and fix vulnerabilities.
For details about how HSS scans for vulnerabilities and which types of vulnerability it scans for, see HSS Vulnerability Management Overview.
- Viewing Vulnerability Details: describes how to view vulnerability details.
- Fixing Vulnerabilities: If HSS detects a vulnerability on a server, you need to handle the vulnerability in a timely manner based on its severity and your business conditions to prevent further vulnerability exploits. If a vulnerability may harm your services, fix it as soon as possible. For Linux and Windows vulnerabilities, you can go to the HSS console and fix them in one-click. Web-CMS, website, emergency, and application vulnerabilities cannot be automatically fixed. You can handle them by referring to suggestions provided on the vulnerability details page.
- Ignoring and Unignoring a Vulnerability: Some vulnerabilities are risky only in specific conditions. For example, if a vulnerability can be exploited only through an open port, but there are no open ports on the target server, the vulnerability will not harm the server. Such vulnerabilities can be ignored. HSS will still generate alerts when next time it finds the vulnerabilities you ignore before. SecMaster will synchronize the vulnerability information as well. If you need to pay attention to an ignored vulnerability again, you can cancel the previous ignoring operation.
- Importing and Exporting Vulnerabilities: describes how to import or export vulnerabilities.
ECS Vulnerabilities
ECS vulnerabilities are reported by HSS to SecMaster, and SecMaster displays them in real time. You can view vulnerability details and get fixing suggestions.
The following ECS vulnerabilities can be detected:
Check Items |
Description |
Linux software vulnerability detection |
SecMaster detects vulnerabilities in the system and software (such as SSH, OpenSSL, Apache, and MySQL) based on vulnerability libraries, reports the results to the management console, and generates alerts. |
Windows OS vulnerability detection |
SecMaster subscribes to Microsoft official updates, checks whether the patches on the server have been updated, pushes Microsoft official patches, reports the results to the management console, and generates vulnerability alerts. |
Web-CMS vulnerability detection |
SecMaster checks web directories and files for Web-CMS vulnerabilities, reports the results to the management console, and generates vulnerability alerts. |
Application Vulnerabilities |
SecMaster detects the vulnerabilities in the software and dependency packs running on the server, reports risky vulnerabilities to the console, and displays vulnerability alerts. |
The vulnerability severity levels in SecMaster and vulnerability fix priorities in HSS are as follows:
- HSS: The vulnerability fix priority is weighted based on the CVSS score, release time, and the importance of the assets affected by the vulnerability. It reflects the urgency of the fix.
HSS classifies vulnerability fix priorities into four levels: critical, high, medium, and low. You can refer to the priorities to fix the vulnerabilities that have significant impact on your server first.
- SecMaster: displays the vulnerability severity. The severity is determined based on the highest CVSS score of the vulnerability. It reflects how severe the vulnerability is.
SecMaster classified vulnerability severity into four levels: high, medium, low, and informative. You can fix vulnerabilities based on their severity.
Website Vulnerabilities
Website vulnerabilities are vulnerabilities found on websites. Currently, only manually importing vulnerability data is supported. Note that website vulnerabilities cannot be automatically fixed. You can manually fix them by referring to the suggestions provided on the vulnerability details page.
