Data Collection Process
The following figure shows the log data collection process.
Figure 1 Data collection process
Table 1 Description of the security data collection process
No.
Step
Adding a Node
Select or purchase an ECS and install the component controller on the ECS to complete node management.
2
Installing Components
Install data collection engine Logstash on the Components tab to complete component installation.
3
Configuring Connectors
Configure the source and destination connectors. Select a connector as required and set parameters.
4
(Optional) Configuring a Parser
Configure codeless parsers on the console based on your needs.
5
Configuring a Collection Channel
Configure the connection channels, associate it with a node, and deliver the Logstash pipeline configuration to complete the data collection configuration.
6
Verifying the Collection Result
After the collection channel is configured, check whether data is collected.
If logs are sent to the SecMaster pipeline, you can query the result on the SecMaster Security Analysis page.
Data Collection Configuration Removal Process
Figure 2 Data collection configuration removal process
Table 2 Description of the data collection configuration removal process
No.
Step
Deleting a collection channel
On the Collection Channels page, stop and delete the Logstash pipeline configuration.
Note: All collection channels on related nodes must be stopped and deleted first.
2
(Optional) Deleting a parser
If a parser is configured, delete it from the Parsers tab.
3
(Optional) Deleting a data connection
If a data connection is added, delete the source and destination connectors from the Connections tab.
4
Removing a component
Delete the collection engine Logstash installed on the node and remove the component.
5
Deregistering a node
Remove the component controller to complete node deregistration.
Note: Deregistering a node does not delete the ECS and endpoint resources. If the data collection function is no longer used, you need to manually release the resources. For details, see How Do I Release an ECS or VPC Endpoint? and Deleting a VPC Endpoint.
