Managing Check Plans
This topic describes how to manage check plans under Baseline Inspection.
Limitations and Constraints
  • The default check plan can be enabled or disabled only. No changes on its compliance packs or execution time can be made.
  • You can edit and delete custom check plans only.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
  4. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  5. In the navigation pane on the left, choose Risk Prevention > Baseline Inspection. On the displayed page, click the Security Standards tab. Then, click the Check Plan tab.
    Figure 2 Check Plan tab
  6. On the Check Plan page, manage check plans.
    Table 1 Check plan management
    Operation
    Viewing a check plan
    On the Check Plan tab, you can view the name, execution time, and compliance packs of a check plan.
    Editing a custom check plan
    1. In the upper right corner of the check plan box, click Edit. The pane for editing the check plan is displayed on the right.
    2. Edit settings and click OK.
    Disabling or enabling a check plan
    Toggle on or off the status button in the box where the target check plan is located.
    Deleting a custom check plan
    1. In the upper right corner of the check plan box, click Delete.
    2. In the displayed dialog box, click OK.
