Help Center/
SecMaster/
User Guide/
Risk Prevention/
Baseline Inspection/
Importing and Exporting Check Items
Updated on 2024-11-21 GMT+08:00
This topic describes how to import and export check items.
Limitations and Constraints
When you import check items, note the following restrictions:
- Only .xlsx files can be imported.
- Only one file can be imported at a time. Maximum file size: 100 records.
Importing Check Items
- Click in the upper left corner of the management console and select a region or project.
- Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
. On the displayed page, click the Security Standards tab. Then, click the Check Item tab.Figure 2 Accessing the Check Item tab
- In the upper left corner above the check item list, click Import.
- In the dialog box displayed, click Download Template and complete the template.
- In the displayed dialog box, click Add File and upload the completed template file.
- Click OK.
Figure 3 Workspace management page
. On the displayed page, click the Security Standards tab. Then, click the Check Item tab.Figure 4 Accessing the Check Item tab
- Select check items you want to export from the check item list and click Export in the upper left corner above the list.
- In the displayed dialog box, select the format and data columns you want.
- Click Export.
Parent topic: Baseline Inspection
