Help Center/ SecMaster/ User Guide/ Risk Prevention/ Baseline Inspection/ Importing and Exporting a Compliance Pack
Updated on 2024-11-21 GMT+08:00
This section describes how to import and export a compliance pack.
Limitations and Constraints
When you import a compliance pack, note the following restrictions:
  • Only .xlsx files can be imported.
  • Only one file can be imported at a time. Maximum file size: 100 records.
Importing a Compliance Pack
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
  4. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  5. In the navigation pane on the left, choose Risk Prevention > Baseline Inspection. On the displayed page, click the Security Standards tab. Then, click the Compliance Pack tab.
    Figure 2 Accessing the Compliance Pack tab
  6. In the upper left corner above the compliance pack list, click Import.
  7. In the dialog box displayed, click Download Template and complete the template.
  8. In the displayed dialog box, click Add File and upload the completed template file.
  9. Click Import.
    Figure 3 Workspace management page
    Figure 4 Accessing the Compliance Pack tab
  6. Select the target compliance pack and click Export in the upper left corner of the compliance pack list.
  7. In the displayed dialog box, select the format and data columns you want.
  8. Click Export.
