Help Center/ SecMaster/ User Guide/ Risk Prevention/ Baseline Inspection/ Creating a Custom Compliance Pack
Updated on 2024-09-27 GMT+08:00
This topic walks you through on how to create a custom compliance pack.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
  4. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  5. In the navigation pane on the left, choose Risk Prevention > Baseline Inspection. On the displayed page, click the Security Standards tab. Then, click the Compliance Pack tab.
    Figure 2 Accessing the Compliance Pack tab
  6. In the upper left corner above the compliance list, click Add
  7. On the displayed page, configure basic information about the compliance pack.
    Table 1 Basic information
    Compliance Pack
    The compliance pack name you specify.
    Description of the compliance pack.
    (Optional) Advanced
    Version
    Set the compliance pack version.
    Classify
    Enter the category the compliance pack belongs to.
    Domain
    Enter the domain the compliance pack belongs to.
    Owner
    The people in charge of the compliance pack.
    Applicable Region
    Enter the region where the compliance pack is used.
  8. Click Next to go to the configuration page.
  9. On the displayed page, complete other parameters of the compliance pack.
    1. In the navigation pane on the left, click . In the displayed text box, enter the node name and click OK.
      • Adding a subnode: To add a level-2 or level-3 node, hover over the node name and click the Create button. In the text box displayed, enter the node name and press Enter.
      • Editing or deleting a node: To edit or delete a node, hover over the node name and click the Edit or Delete button.
    2. Select the name of an added node (minimum level. For example, if a level-3 node is added, select the level-3 node name). In all check items displayed on the right, select the check items you want to associate.
    Figure 3 Compliance pack configuration
  10. Click Next to enter the confirmation page.
  11. Confirm the settings and click OK.
Related Operations
  • Disabling a compliance pack
    1. In the row that contains the target compliance pack, click Disable in the Operation column.
    2. In the displayed dialog box, click OK.
  • Enabling a compliance pack
    1. Click Enable in the Operation column of the compliance pack you want to enable.
  • Editing check items in a compliance pack
    1. Click the name of the compliance pack you want to edit to go to its details page.
    2. Click Edit in the Compliance Pack Content area.
    3. Edit check node information and their associated check items and click OK.
  • Deleting a compliance pack
    1. In the row that contains the compliance pack you want to delete, click Delete in the Operation column.
    2. In the displayed dialog box, enter DELETE and click OK.
