Help Center/
SecMaster/
User Guide/
Security Orchestration/
Operation Object Management/
Classification & Mapping/
Viewing Categorical Mappings
Updated on 2024-11-21 GMT+08:00
Categorical mappings are used to match alert types and map alert fields for aloud service alerts.
This section describes how to view categorical mappings.
- Click in the upper left corner of the management console and select a region or project.
- Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Objects. On the page displayed, click the Classify&Mapping tab.
Figure 2 Classify&Mapping tab page
- On the Classify&Mapping tab, view details about the created categorical mappings.
- In the categorical mapping list, view details such as the categorical mapping name, data class, and number of associated plug-in instances.
- If there are so many categorical mappings, you can use filters and keywords to search for a specific one.
- To edit a categorical mapping, click its name to go to the edit page.
On the edit page, you can edit details about the categorical mapping.
- In the categorical mapping list, you can also enable, disable, clone, and delete a categorical mapping.
Parent topic: Classification & Mapping
