- What's New
- Function Overview
Billing
- Billing Overview
- Billing Modes
- Billing Items
- Billing Examples
- Changing the Billing Mode
- Renewing Your Subscription
- Bills
- About Arrears
- Billing Termination
- Cost Management
Billing FAQs
- How Is SecMaster Billed?
- Can I Use SecMaster for Free?
- How Do I Change or Disable Auto Renewal for SecMaster?
- Will SecMaster Be Billed After It Expires?
- How Do I Renew SecMaster?
- Where Can I Unsubscribe from SecMaster?
- Where Can I View the Remaining Quotas of Security Data Collection and Security Data Packages?
- Can I Change the Billing Mode for SecMaster?
- Getting Started
User Guide
- Buying SecMaster
- Authorizing SecMaster
- Checking Security Overview
- Workspaces
- Viewing Purchased Resources
Security Governance
- Security Governance Overview
- Security Compliance Pack Description
- Authorizing SecMaster to Access Cloud Service Resources
- Subscribing to or Unsubscribing from a Compliance Pack
- Starting a Self-Assessment
- Viewing Security Compliance Overview
- Viewing Evaluation Results
- Viewing Policy Scanning Results
- Downloading a Compliance Report
- Security Situation
- Resource Manager
- Risk Prevention
- Threats
- Security Orchestration
Playbook Overview
- Ransomware Incident Response Solution
- Attack Link Analysis Alert Notification
- HSS Isolation and Killing of Malware
- Automatic Renaming of Alert Names
- Auto High-Risk Vulnerability Notification
- Automatic Notification of High-Risk Alerts
- Auto Blocking for High-risk Alerts
- Real-time Notification of Critical Organization and Management Operations
Settings
- Data Integration
Log Data Collection
- Data Collection Overview
- Data Collection Process
- Adding a Node
- Configuring a Component
- Adding a Connection
- Creating and Editing a Parser
- Adding and Editing a Collection Channel
- Verifying Log Collection
- Managing Connections
- Managing Parsers
- Managing Collection Channels
- Viewing Collection Nodes
- Managing Nodes and Components
- Partitioning a Disk
- Logstash Configuration Description
- Connector Rules
- Parser Rules
- Upgrading the Component Controller
- Customizing Directories
- Permissions Management
- Key Operations Recorded by CTS
Best Practices
Log Access and Transfer Operation Guide
- Solution Overview
- Resource Planning
- Process Flow
- (Optional) Step 1: Buy an ECS
- (Optional) Step 2: Buy a Data Disk
- (Optional) Step 3: Attach a Data Disk
- Step 4: Create a Non-administrator IAM User
- Step 5: Configure Network Connection
- Step 6: Install the Component Controller (isap-agent)
- Step 7: Install the Log Collection Component (Logstash)
- (Optional) Step 8: Creating a Log Storage Pipeline
- Step 9: Configure a Connector
- (Optional) Step 10: Configure a Log Parser
- Step 11: Configure a Log Collection Channel
- Step 12: Verify Log Access and Transfer
- Credential Leakage Response Solution
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Alert Management
- Incident Management
- Indicator Management
- Playbook Management
- Alert Rule Management
- Playbook Version Management
- Playbook Rule Management
- Playbook Instance Management
- Playbook Approval Management
- Playbook Action Management
- Incident Relationship Management
- Data Class Management
- Workflow Management
- Data Space Management
- Pipelines
- Workspace Management
- Metering and Billing
- Metric Query
- Baseline Inspection
- Appendix
- FAQs
More Documents
- Buying SecMaster
- Viewing Security Overview
- Workspaces
Security Governance
- Resource Manager
- Risk Prevention
- Threat Operations
Settings
- Data Integration
Log Data Collection
- Adding a Node
- Managing Parsers
- Connector Rules
- Parser Rules
- FAQs
- Change History
- Security Overview
- Workspaces
- Resource Manager
Risk Prevention
Baseline Inspection
- Baseline Inspection Overview
- Creating a Custom Check Plan
- Starting an Immediate Baseline Check
- Viewing Check Results
- Handling Check Results
- Viewing Compliance Packs
- Creating a Custom Compliance Pack
- Importing and Exporting a Compliance Pack
- Viewing Check Items
- Creating a Custom Check Item
- Importing and Exporting Check Items
- Vulnerability Management
- Policy Management
Baseline Inspection
Threat Operations
- Alert Management
- Intelligent Modeling
- Security Analysis
- Data Delivery
- Security Orchestration Overview
- Built-in Playbooks
- Security Orchestration Process
- (Optional) Configuring and Enabling a Workflow
- Configuring and Enabling a Playbook
- Operation Object Management
- Playbook Orchestration Management
- Layout Management
- Plug-in Management
- Settings
Product Consulting
- Why Is There No Attack Data or Only A Small Amount of Attack Data?
- Where Does SecMaster Obtain Its Data From?
- What Are the Dependencies and Differences Between SecMaster and Other Security Services?
- What Are the Differences Between SecMaster and HSS?
- How Do I Update My Security Score?
- How Do I Handle a Brute-force Attack?
- Issues About Data Synchronization and Data Consistency
- About Data Collection Faults
Product Consulting
- Change History
Show all
Overview
You can use SecMaster to manage and maintain tasks across accounts with ease, making it simple to implement protection of different services, including WAF, CFW, VPC security groups and IAM. You can view all policies centrally, manage policies for seven defense lines manually, and query manual and automatic block records quickly.
- Viewing and Configuring Defense Policies: describes how to view and configure defense policies. There are seven defense lines: physical, identity, server, maintenance, data, application, and network defense lines. Table 1 describes the seven layers of defense and the corresponding asset types that can be protected.
Table 1 Seven layers of defense and types of protected assets Defense Layer Type
Protection Plan
Protected Asset Type
Physical security
The cloud service provider is responsible for physical environment security.
Network security
DDoS Mitigation
This solution mitigates DDoS attacks in milliseconds to ensure continuity of your global services based on machine learning, protection policy tuning, and precise identification of DDoS attacks.
Elastic Load Balance (ELB) and Elastic IP (EIP)
Cloud Firewall (CFW)
Cloud Firewall (CFW) protects Internet borders on the cloud and at VPC borders. It can detect and defend against intrusions in real time, control traffic in a unified manner, analyze traffic and visualize results, audit logs, and trace traffic sources. You can scale CFW resources as needed.
Virtual Private Cloud (VPC)
Application security
Web Application Firewall (WAF)
WAF can check and protect website service traffic from multiple dimensions. WAF can intelligently identify malicious request features and defend against unknown threats based on deep machine learning.
Websites and IP addresses
Server security
Host Security Service (HSS)
HSS is designed to protect server workloads in hybrid clouds and multi-cloud data centers. It protects servers and containers and prevents web pages from malicious modifications.
Elastic Cloud Server (ECS) and Cloud Container Engine (CCE)
The defense layers for the identity, data, and O&M security will be available soon.
- Adding an Emergency Policy: Emergency policies are used to quickly prevent attacks. You can select a block type based on the alert source to block attackers.
- Managing Emergency Policies: describes Viewing an Emergency Policy, Editing an Emergency Policy, and Deleting an Emergency Policy.
- Batch Blocking and Canceling Batch Blocking of an IP Address or IP Address Range: describes how to block access from blacklisted IP addresses, IAM users, or IP address ranges. You can add an IP address, IAM user, or IP address range as blocked object for an emergency policy in several operation connections. If there is no need to block an IP address, IAM user, or IP address range for operation connections, you can cancel the blocking from all operation connections.
Limitations and Constraints
- Currently, the emergency policies include only the blacklist policies of CFW, WAF, VPC security groups and IAM.
- A maximum of 300 emergency policies that support block aging can be added for a single workspace you have. A maximum of 1,300 emergency policies can be added for a single workspace you have. Limits on blocked objects at a time are as follows:
- When a policy needs to be delivered to CFW, each time a maximum of 50 IP addresses can be added as blocked objects for each account.
- When a policy needs to be delivered to WAF, each time a maximum of 50 IP addresses can be added as blocked objects for each account.
- When a policy needs to be delivered to VPC, each time a maximum of 20 IP addresses can be added as blocked objects within 1 minute for each account.
- When a policy needs to be delivered to IAM, each time a maximum of 50 IAM users can be added as blocked objects for each account.
- If an IP address or IP address range or an IAM user is added to the blacklist, CFW, WAF, VPC, and IAM will block requests from that IP address or user without checking whether the requests are malicious.
