Help Center/ SecMaster/ User Guide/ Resource Manager/ Editing or Deleting an Asset
Updated on 2026-10-10 GMT+08:00
On the Resource Manager page, you can edit the department, service system, and owner of an asset. You can also delete assets you imported into SecMaster if needed. You can delete them one by one or in batches.
This topic describes how to edit or delete assets from SecMaster.
  • Both on-cloud and off-cloud assets can be edited.
  • Only assets imported from outside our cloud can be deleted. Assets on our cloud cannot be deleted.
You have purchased the SecMaster standard or professional edition.
Notes and Constraints
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Resource Manager > Resource Manager.
    Figure 2 Resource Manager
  5. Edit or delete the asset.
    Table 1 Parameters for asset edit or deletion
    Operation
    Edit
    Editing a resource
    1. On the Resource Manager page, select the resources you want to edit and click Edit in the upper left corner of the resource list.
      To edit a resource of a certain type, click the corresponding resource type tab. For example, if you want to edit servers, click the Servers tab.
    2. In the displayed box, you can edit the service system of the resource.
    3. Click OK.
    4. On the Resource Manager page, click the corresponding resource tab to view resource information in the resource list.
    Edit a department
    1. On the Resource Manager page, click the Service Systems & Departments tab and click next to Department.
    2. In the displayed Edit Dept dialog box, edit Dept Name.
    3. Click OK.
    4. On the Resource Manager page, click the Service Systems & Departments tab and view the modified department name.
    Editing a service system
    1. On the Resource Manager page, click the Service Systems & Departments tab. In the Service System list, click Edit in the Operation column of the target service system.
    2. In the Edit dialog box, edit Service Systems & Departments, select the department where the service system is located for Department, edit Owner, and set the assets associated with the service system.
    3. Click OK.
    4. On the Resource Manager page, click the Service Systems & Departments tab and view the modified service system.
    Delete
    Deleting a resource
    1. On the Resource Manager page, click the corresponding resource type tab. For example, if you want to delete servers, click the Servers tab.
    2. On the displayed page, select the resources you have imported but want to delete and click Batch Delete above the list.
    3. The system will delete all selected resources.
    Deleting a department
    2. Click next to the department you want to delete.
    3. In the displayed Delete Dept dialog box, confirm the information, click DELETE, and click OK.
    Deleting a service system
    2. Select the Service System you want to delete and click Delete in the Operation column or Delete above the service system list.
    3. In the displayed Delete Service System dialog box, confirm the information, click DELETE, and click OK.
