Updated on 2026-02-06 GMT+08:00
Vulnerable Assets Screen
There are always such scenarios as presentation, reporting, or real-time monitoring where you need to present the analysis results of SecMaster on big screens to achieve better demonstration effect. It is not ideal to just zoom in the console. Now, SecMaster Large Screen is a good choice for you to display the service console on bigger screens for a better visual effect.
By default, SecMaster provides a vulnerability situation screen. With this screen, you can view the overview of vulnerable assets, asset vulnerabilities, unsafe baseline settings, and unprotected assets.
You have enabled Large Screen. For details, see Buying Value-Added Packages.
Viewing the Vulnerable Assets Screen
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Situation Awareness > Large Screen.
    Figure 2 Large Screen
  5. Click Play in the lower right corner of the vulnerable assets image to access the screen.
    This screen includes many graphs. More details are provided below.
Vulnerable Assets Overview
This graph displays the total numbers of vulnerable assets, vulnerabilities, unsafe baseline settings, and unprotected assets. Figure 3 shows an example.
Vulnerable assets refer to assets with unhandled vulnerabilities or unsafe baseline settings and assets that are not under protection at the current time.
Table 1 Vulnerable Assets Overview
Statistical Period
Update Frequency
Vulnerable Assets
Real-time
Hourly
The number of assets with vulnerabilities or risky baseline settings.
Vulnerabilities
Real-time
Hourly
Vulnerabilities collected in Vulnerabilities.
Risky Baseline Settings
Real-time
Hourly
Data reported by Baseline Inspection in SecMaster.
Unprotected Assets
Real-time
Hourly
Number of assets for which you need to enable security protection, for example, ECSs for which HSS is not enabled and EIPs for which DDoS is not enabled.
Figure 3 Vulnerable Assets Screen
Top 5 Departments with the Most Vulnerabilities
This graph shows the five departments with the most vulnerabilities. You will view the details of these departments, including the department name, number of vulnerable assets, number of unfixed vulnerabilities, and number of unprotected assets. Figure 4 shows an example.
Table 2 Vulnerable departments
Statistical Period
Update Frequency
Top 5 Vulnerable Departments
Real-time
Hourly
The five departments have the most vulnerable assets, assets affected by vulnerabilities, and unprotected assets.
Vulnerable assets include assets affected by vulnerabilities in Risk Prevention > Vulnerabilities, and assets that fail any check in Risk Prevention > Baseline Inspection, and assets that are not protected in Resource Manager. Note that the assets in Resource Manager must have department details provided, or they cannot be counted in calculation.
Figure 4 Top 5 Vulnerable Departments
Top 5 Department with the Most Unprotected Assets
This graph displays the five departments with the most failed protection policies. You can view the details about these departments, including the department name and what protection policies they failed, such as DBSS, WAF, Anti-DDoS, HSS, and CFW. Figure 5 shows an example.
The graph displays the five departments with the most unprotected assets.
Table 3 Department with the most unprotected assets
Statistical Period
Update Frequency
Real-time
Hourly
The five departments with the most unprotected assets.
Figure 5 Top 5 Department with the Most Unprotected Assets
Vulnerability Fix Rate
This graph shows the vulnerability fix rate, top 5 vulnerability types, and vulnerability trend changes. Figure 6 shows an example.
Table 4 Vulnerability fix rate
Statistical Period
Update Frequency
Real-time
Hourly
Vulnerability fixing rate =(Number of fixed vulnerabilities/Total number of vulnerabilities) x 100%.
If no vulnerability exists, 100% is displayed.
Vulnerability Types
Real-time
Hourly
Vulnerabilities are displayed by vulnerability type.
Vulnerability Changes
Last 7 days
Hourly
Vulnerabilities in the last seven days are classified and counted by severity.
Figure 6 Vulnerability fixing rate
Baseline Inspection Pass Rate
You can learn about baseline inspection results at a glance, including the pass rate, what resources have failed the inspection, failed checks, resource types, and the number of total check items. Figure 7 shows an example.
Table 5 Baseline Inspection Pass Rate
Statistical Period
Update Frequency
Real-time
Hourly
Baseline check pass rate =(Number of passed baseline check items/Total number of check items) x 100%.
Failed Checks By Type
Real-time
Hourly
Failed baseline check items are displayed by risk severity.
Baseline Inspection
Real-time
Hourly
This graph shows how many qualified, risky, and unqualified settings, respectively, discovered by baseline inspection.
Figure 7 Baseline Inspection Pass Rate
