Updated on 2026-09-14 GMT+08:00
Directory Customization
You can customize directories on SecMaster. This section includes the following content:
  • Viewing Existing Directories: You can view the directory status, directory name, and associated layout.
  • Changing a Layout: You can change the directory layout to change the information displayed on the directory page. The information is displayed based on the new layout.
Notes and Constraints
  • Built-in directories cannot be edited or deleted.
  • Only the Resource Manager, Incidents, Alerts, Indicators, and Vulnerabilities pages support layout changes.
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Security Orchestration > Directory Customization.
    Figure 2 Directory Customization page
  5. In the directory list, view the directory details.
    Table 1 Directory parameters
    Display Breadcrumb Navigation
    This function is enabled by default. This parameter determines whether users can return to the upper-level navigation directory.
    • Enabled: Users can return to the outer workspace management navigation directory.
    • If this function is disabled, users cannot return to the outer workspace management navigation directory.
    Workspace Navigation Settings
    • Add: You can add a custom directory.
    • Edit: You can edit multiple directories at a time, set Landing Page, and configure Display. The landing page is the default page displayed after you click a workspace name.
    • Delete: You can delete multiple directories at a time. Only custom directories can be deleted. Built-in directories cannot be deleted.
    Navigation Name
    Name of the level-1 directory that the navigation belongs to. You can click next to the level-1 directory name to expand the level-2 directory names of the level-1 directory.
    Status
    Type of the directory.
    Publisher
    Publisher of the directory. The default publisher of a built-in directory is CloudService.
    Layout
    Layout associated with the directory.
    Address
    Address of the directory. URL of the directory page. The URL is automatically generated by the system.
    Chinese Alias
    Chinese name of the directory.
    Alias
    English name of the directory.
    Landing Page
    Default page that is displayed when you click a workspace name.
    • A workspace must have a landing page.
    • Only one directory that can be displayed can be set as the landing page.
    • A level-1 directory cannot be set as a landing page.
    Display
    Whether the directory is displayed in the navigation pane.
    Operation
    Operations you can do for the directory. You can edit a directory and change the layout.
    Edit: You can edit Chinese Alias, Alias, Landing Page, and Display of the directory.
    Change Layout: You can change the layout of a custom directory or a built-in directory that is associated with a layout. Only other layouts of the same type can be replaced.
Changing a Layout
    Figure 3 Workspace management page
    Figure 4 Directory Customization page
  5. Click Change Layout in the Operation column of the target directory.
  6. On the Change Layout page, select the layout to be changed.
  7. Click OK.
