Viewing Threat Intelligence Types
This section describes how to view threat intelligence types. For details about preset threat indicator types, see Preset Threat Indicator Types.
Limitations and Constraints
- By default, built-in intelligence types are associated with existing layouts. You cannot customize associated layouts.
- Built-in intelligence types are enabled by default and cannot be edited, enabled, disabled, or deleted.
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the upper left corner of the page and choose Security & Compliance > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Type Management tab.
. On the displayed page, click the Figure 2 Type Management page
- On the Type Management page, click the Threat Intelligence tab.
- On the Threat Intelligence page, view details. For details about the parameters, see Table 1.
Table 1 Threat intelligence type parameters Parameter
Type Name/Type Tag
Name and type tag of threat intelligence
Associated Layout
Layout associated with threat intelligence
Startup Status
Indicates the enabling status of a threat intelligence type:
- Enabled: The current type has been enabled.
- Disabled: The current type has been disabled.
Expired Time
Expiration time of threat intelligence.
Built-in
Indicates whether the indicator was built in the system.
Description of a threat intelligence
Operation
You can edit and delete the threat intelligence.
