Updated on 2026-02-06 GMT+08:00
Managing Workflows
This topic describes how to manage workflows, including Viewing Workflows, Exporting Workflows, Deleting Workflows, Copying a Workflow, and Disabling a Workflow.
  • Viewing Workflows: View the information about existing workflows, such as the number, status, and version of workflows.
  • Exporting Workflows: Quickly export existing workflows.
  • Deleting Workflows: Delete workflows that are no longer used. You can only delete a disabled workflow that does not have any activated version. During deletion, all historical versions in the workflow are deleted by default. Deleted versions cannot be restored.
  • Disabling a Workflow: Disable workflows when you do not want to enable them but want to retain their configurations. If a workflow is disabled, its Workflow Status changes to Disabled on the Workflows page.
  • Copying a workflow: You can quickly create a workflow by copying an existing one.
Viewing Workflows
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Security Orchestration > Playbooks. On the displayed page, select the Workflows tab.
    Figure 2 Workflows tab
  5. On the Workflows page, view details about the created workflow.
    Figure 3 Viewing workflows
    • The numbers of Pending review, Not enabled, and Enabled workflows are displayed above the workflow list.
    • View information about existing workflows in the workflow list.
      If there are many workflows displayed, use filters to search for a specific one.
      Table 1 Workflow parameters
      Name
      Workflow name
      Data Class
      Data class corresponding to a workflow.
      Workflow Status
      Current status of a workflow. The status can be Enabled or Disabled.
      Workflow Type
      Current type of a workflow.
      Current Version
      Current version of a workflow.
      Created By
      User who creates the workflow.
      Created
      Time when a workflow was created
      Updated By
      User who modifies the workflow last time.
      Updated At
      Time when a workflow is last updated.
      A description of the workflow.
      Operation
      You can perform operations such as enabling and managing versions in the Operation column.
    • To view details about a workflow, click its name to access its details page.
Exporting Workflows
Only workflows in the Enabled state can be exported.
    Figure 4 Workspace management page
    Figure 5 Workflows tab
  5. On the Workflows tab page, select the workflows to be exported and click in the upper right corner of the list.
  6. In the dialog box that is displayed, click OK. The system exports the workflows to the local host.
Deleting Workflows
All of the following conditions must be met before you can delete a workflow:
  • The workflow is in the Disabled state.
  • The workflow does not contain an activated workflow version.
    Figure 6 Workspace management page
    Figure 7 Workflows tab
  5. On the Workflows tab page, locate the row containing the target workflow and click More > Delete in the Operation column.
  6. In the displayed dialog box, enter DELETE and click OK.
    During deletion, all historical versions in the current workflow are deleted by default. Deleted versions cannot be restored.
    Figure 8 Workspace management page
    Figure 9 Workflows tab
  5. In the row containing the target workflow, click Disable in the Operation column.
  7. Check the workflow status. If its status changes to Disabled on the Workflows tab, the workflow has been disabled.
Copying a Workflow
    Figure 10 Workspace management page
    Figure 11 Workflows tab
  5. In the Operation column of the target workflow, click Copy Workflow to open the Copy Workflow dialog box.
  6. In the Copy Workflow dialog box, configure the following parameters.
    Table 2 Parameters for copying a workflow
    Source Version
    Select the version you want to copy and click OK. A new workflow will be generated.
    To copy a workflow, there must be at least one existing workflow version.
    You can only select a value from the drop-down list.
    Workflow Name
    Specify a name for the new workflow.
    • The workflow name must be unique.
    • The workflow name cannot be empty.
    • The workflow name can contain 1 to 64 characters. Only letters, digits, periods (.), hyphens (-), underscores (_), and spaces are allowed.
  7. Click OK. You can choose Security Orchestration > Playbooks, click the Workflows tab, and view the information about the new workflow. Now, you need to submit the workflow version for review before enabling it. For details, see Editing and Submitting a Workflow Version, Reviewing a Workflow Version, and Enabling a Workflow.
