Managing Playbook Versions
This section describes how to manage playbook versions, including Previewing Playbook Versions, Editing a Playbook Version, Activating/Deactivating a Playbook Version, Copying a Playbook Version, and Deleting a Playbook Version.
- Previewing Playbook Versions: View playbook version information.
- Editing a Playbook Version: Only playbook versions not submitted can be edited. You can modify the playbook version information.
- Copying a Playbook Version: If you want to use a playbook that is not enabled, you can modify the playbook version and then enable it. To enable a custom playbook version, take the following steps:
- Activating/Deactivating a Playbook Version: Only one activated playbook version is allowed for each playbook. Only the inactivated playbook version can be activated. Once the current version is activated, the previously activated version will be deactivated. For example, if you activate version V2, version V1 in the Activated state will be deactivated. You can change the playbook version in use by referring to Activating/Deactivating a Playbook Version.
- Deleting a Playbook Version: Deleted playbook versions cannot be restored. Exercise caution when performing this operation. You can delete a workflow version that is no longer used.
The draft version cannot be previewed.
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 1 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Playbooks. Figure 2 Accessing the Playbooks tab
- On the Playbooks tab, click Version Management in the Operation column of the playbook.
- On the Version Management slide-out panel, in the version information area, locate the row containing the desired playbook version, and click Preview in the Operation column.
- On the playbook version preview page, you can view the details about the target playbook version, including Basic Information, Version Information, and Matching Workflow.
Only playbook versions whose version status is Unsubmitted can be edited.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 3 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Playbooks. Figure 4 Accessing the Playbooks tab
- On the Version Management slide-out panel, in the version information area, locate the row containing the desired playbook version, and click Edit in the Operation column.
- On the page for editing a playbook version, edit the version information.
- Click OK.
- Only the playbook version that is not activated can be activated.
- Only one activated version is allowed for each playbook.
- After the current version is activated, the previously activated version is deactivated. For example, if the V2 version is activated this time, the V1 version in the activated state is deactivated and changes to the deactivated state.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 5 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Playbooks. Figure 6 Accessing the Playbooks tab
- On the Version Management page, in the version information area, locate the row containing the desired playbook version, and click Activate or Deactivate in the Operation column.
- After the operation is complete, view the version information on the playbook version management page and check the Status of the playbook version.
Only playbook versions in the Activated or Inactive state can be copied.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 7 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Playbooks. Figure 8 Accessing the Playbooks tab
- On the Version Management slide-out panel, in the version information area, locate the row containing the desired playbook version, and click Copy in the Operation column.
- In the dialog box that is displayed, click OK.
- Then, check the playbook version. If Version is Draft Version and Status is Draft, the version has been copied.
- The playbook version is inactivated.
- No running playbook version instance exists.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 9 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Playbooks. Figure 10 Accessing the Playbooks tab
- On the Version Management slide-out panel, in the version information area, locate the row containing the desired playbook version, and click Delete in the Operation column.
After a playbook version is deleted, it cannot be retrieved. Exercise caution when performing this operation.
