Updated on 2024-11-21 GMT+08:00
Viewing Data Classes
The playbook and workflow running in security orchestration and response need to be bound to a data class. The playbook is triggered by a data object (instance of the data class).
This section describes how to view existing data classes.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
  4. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  5. In the navigation pane on the left, choose Security Orchestration > Objects. The Data Class tab page is displayed by default.
    Figure 2 Accessing the Data Class tab
  6. In the data class list, view the existing data class information.
    • If there are many data classes displayed, use filters to search for a specific one.
    • In the data class list, you can view the data class name, service code, and whether the data class is a built-in data class.
    • To view details about a data class, click the name of the target data class. The details page of the target data class is displayed on the right.
      On the data class details page, you can view the basic information and fields about the data class.
