SecMaster Operations Recorded by CTS
Cloud Trace Service (CTS) provides you with a history of SecMaster operations. After enabling CTS, you can view all generated traces to query, audit, and review performed SecMaster operations. For details, see Cloud Trace Service User Guide.
Table 1 shows the details about the SecMaster operations on CTS.
Operation |
Resource Type |
Trace Name |
Reviewing a Playbook |
playbook |
approvePlaybook |
Creating a Playbook Action |
playbook |
createPlaybookAction |
Modifying a Playbook Action |
playbook |
updatePlaybookAction |
Deleting a Playbook Action |
playbook |
deletePlaybookAction |
Creating a Playbook |
playbook |
createPlaybook |
Modifying a Playbook |
playbook |
updatePlaybook |
Deleting a Playbook |
playbook |
deletePlaybook |
Operating a Playbook Instance |
playbook |
operatePlaybookInstance |
Exporting a Playbook Instance |
playbook |
exportPlaybookInstance |
Exporting a Playbook |
playbook |
exportPlaybook |
Importing a Playbook |
playbook |
importPlaybook |
Adding a Playbook Triggering Rule |
playbook |
createPlaybookRule |
Updating a Playbook Triggering Rule |
playbook |
updatePlaybookRule |
Deleting a Playbook Triggering Rule |
playbook |
deletePlaybookRule |
Creating a Playbook Version |
playbook |
createPlaybookVersion |
Updating a Playbook Version |
playbook |
updatePlaybookVersion |
Deleting a Playbook Version |
playbook |
deletePlaybookVersion |
Cloning a Playbook Version |
playbook |
clonePlaybookVersion |
Creating a Workflow |
workflow |
createWorkflow |
Modifying a Workflow |
workflow |
updateWorkflow |
Deleting a Workflow |
workflow |
deleteWorkflow |
Creating a Workflow Version |
workflow |
createWorkflowVersion |
Modifying a Workflow Version |
workflow |
updateWorkflowVersion |
Reviewing a Workflow Version |
workflow |
approveWorkflowVersion |
Deleting a Workflow Version |
workflow |
deleteWorkflowVersion |
Exporting a Workflow |
workflow |
exportWorkflow |
Importing a Workflow |
workflow |
importWorkflow |
Creating an Operation Connection |
asset |
createAsset |
asset |
updateAsset |
Deleting an Operation Connection |
asset |
deleteAsset |
Uploading an Attachment |
component |
uploadAttachement |
Creating a Plug-in Template |
component |
createComponentTemplate |
Updating a Plug-in Template |
component |
updateComponentTemplate |
Deleting a Plug-in Template |
component |
deleteComponentTemplate |
Adding Comments |
task |
commentTask |
Submitting a To-Do Task |
task |
commitTask |
Creating a Workspace |
workspace |
createWorkspace |
Deleting a Workspace |
workspace |
deleteWorkspace |
Updating a Workspace |
workspace |
updateWorkspace |
Recollecting Subservice Statistics |
workspace |
recollectServiceStatistics |
