Updated on 2025-08-11 GMT+08:00
Handling a To-Do Task
When a playbook or process task reaches a node, the task needs to be suspended manually so that the playbook or process task can continue.
Process to-do tasks.
A playbook task has been triggered, and manual actions are required for completing the task.
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
  4. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  5. In the navigation pane on the left, choose Situation Awareness > Task Center.
    Figure 2 To-Dos
  6. In the row containing the target to-do task, click Approve in the Operation column.
    The approval mode varies according to the service type.
    • Playbook release: The Playbook Release page is displayed on the right. Enter review comments and approve the playbook as prompted.
    • Process release: The Process Release page is displayed on the right. Enter the Comment and approve the application as prompted.
    • Playbook-Node Review: The Playbook-Node Review page is displayed on the right. You can select Continue or Terminate.
  7. In the navigation pane on the left, choose Situation Awareness > Task Center, click the Completed tab, and check completed tasks.
