Viewing Monitored Playbook Instances
After a playbook is executed, a playbook instance is generated in the playbook instance management list for monitoring. Each record in the instance monitoring list is an instance. You can view the historical instance task list and the statuses of historical instance tasks.
View instance monitoring information.
Limitations and Constraints
The maximum number of retries within a day in a workspace of an account is as follows:
- Manual retries: 100. After a retry, the playbook cannot be retried until the current execution is complete.
- API retries: 100. After a retry, the playbook cannot be retried until the current execution is complete.
- Log in to the SecMaster console.
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the upper left corner of the page and choose Security & Compliance > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Instance Management tab.
. On the displayed page, click the Figure 2 Instance Management page
- On the Instance Management tab, click the Playbook Instances or Workflow Instances tab, and view the instance information. For details about the parameters, see Table 1.
Figure 3 Instances
- You can view the total number of instances below the instance list. You can view a maximum of 10,000 instance records page by page. To view more than 10,000 records, optimize the filter criteria.
- An instance can be stored for a maximum of 180 days.
- To view details about an instance, click the instance name. On the displayed page, you can view the instance workflow, workflow nodes, start time, and end time.
Table 1 Parameters in the instance list Parameter
Instance Name
Name of the instance generated by the system.
Playbook Name
Name of the playbook corresponding to the instance.
Data Class
Operation object of a playbook
Trigger Method
Triggering mode of an instance
- Timer Trigger
- Event Trigger
Status
Status of an instance
- Succeeded: The playbook instance is successfully executed.
- Failed: The playbook instance fails to be executed. You can click Retry in the Operation column to execute the playbook again.
- Running: The playbook instance is running. You can click Terminate in the Operation column to terminate the playbook.
- Retrying: The playbook instance is being retried.
- Terminating: The playbook instance is being terminated.
- Stopped: The playbook instance has been terminated.
Context
Context information of an instance
Instance Creation Time
Time when an instance is created.
Instance Ended
Time when an instance ends.
Operation
You can terminate or retry an instance.
Related Operations
- To stop a running instance, click Terminate in the Operation column of the target instance. After an instance is terminated, no operations are supported.
- To start a failed instance, click Retry in the Operation column.
You can retry instances up to 100 times a day in a workspace. After a retry, the playbook cannot be retried until the current execution is complete.
- If the playbook status is Failed on the Instance Management tab, perform the following steps to view more failure causes:
- On the Instance Management tab, click the Instance Name of the playbook. The instance details page is displayed.
- Click the node in the red box in the canvas. The node parameter information of the failed node is displayed on the right.
Figure 4 Instance details page- On the Node Parameters Information page, you can view the Result, Input Parameter, Output Parameter, Error, and Time information.
Figure 5 Node parameters- Rectify the fault based on the node parameter information, and click Retry on the Instance Management page. If the playbook still cannot be executed, submit a service ticket to locate and rectify the fault.
