Updated on 2024-11-21 GMT+08:00
Deleting a Data Space
This topic describes how to delete a data space that is no longer needed.
Limitations and Constraints
  • The default data space created by the system cannot be deleted.
  • If a pipeline exists in the data space to be deleted, the data space cannot be deleted directly. You need to delete the pipeline before deleting the data space.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner of the page and choose Security & Compliance > SecMaster.
  4. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  5. In the navigation pane on the left, choose Threat Operations > Security Analysis. The security analysis page is displayed.
    Figure 2 Accessing the Security Analysis tab page
  6. In the row containing the desired database, click Delete in the Operation column.
    Figure 3 Deleting a data space
  7. In the dialog box displayed, click OK.
