Deleting a NIC
A protected instance can have up to 12 NICs, including one primary NIC that cannot be deleted. You can perform steps provided in this section to delete a NIC other than the primary one.
- The protection group is in the Available or Protecting state.
- The protected instance is in the Available or Protecting state.
- The primary NIC cannot be deleted.
- Click Service List and choose Storage > Business Recovery Service.
The Business Recovery Service page is displayed.
- In the pane of the protection group for which a NIC is to be deleted from the protected instance, click Protected Instances.
The protection group details page is displayed.
- On the Protected Instances tab, click the protected instance.
The protected instance details page is displayed.
- Click the NICs tab. Then, click Delete in the row that contains the NIC to be deleted.
- Click Yes.
