Updated on 2025-03-07 GMT+08:00
Collecting Logs
  • The disaster recovery gateway has been installed. For Linux clients, the gateway version must be 24.6.0 or later. For Windows clients, the gateway version must be 24.9.0 or later.
  • Proxy clients have been installed on target production site servers. For Linux clients, the client version must be 24.6.0 or later. For Windows clients, the client version must be 24.9.0 or later.
  • The total size of collected log files on a single client cannot exceed 400 MB.
In the following example, sdrs_xxxx_24.9.0.xxxx.tar.gz is the proxy client package (24.9.0) used for illustration.
  1. Log in to the gateway server and run the following command as user root to collect logs in a batch:
    /opt/cloud/sdrs/sidecar/script/cmd_tools.sh log --ip=ip_list --role=role
    Parameter description:
    --ip: The private IP addresses of the production site servers you want to collect logs. Separate multiple IP addresses with commas (,).
    --role: The role of the process whose logs need to be collected. The value can be hostagent, drm, dra, sidecar, or all.
    A complete example command is as follows:
    /opt/cloud/sdrs/sidecar/script/cmd_tools.sh log --ip=192.168.0.6,192.168.0.188,192.168.0.204 --role=hostagent
  2. If "send cmd successfully" is returned, the command is successfully sent. View the collected log files in the /opt/cloud/sdrs/sidecar/tmp directory. Because the command is executed asynchronously, so wait for 2 minutes and then check the files.
