- What's New
- Product Bulletin
- Getting Started
User Guide
- Permissions Management
Asynchronous Replication
- Managing a Replica Pair
- Managing a Protection Group
- Managing Protected Instances
- Managing DR Drills
- Managing Clients
- Synchronous Replication Management (for Installed Base Operations)
- Appendixes
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
SDRS APIs
- Job
- API Version
- Active-Active Domain
Protection Group
- Creating a Protection Group
- Querying Protection Groups
- Querying the Details of a Protection Group
- Deleting a Protection Group
- Changing the Name of a Protection Group
- Enabling Protection or Enabling Protection Again for a Protection Group
- Disabling Protection for a Protection Group
- Performing a Failover for a Protection Group
- Performing a Planned Failover for a Protection Group
Protected Instance
- Creating a Protected Instance
- Deleting a Protected Instance
- Querying Protected Instances
- Querying Details About a Protected Instance
- Changing the Name of a Protected Instance
- Attaching a Replication Pair to a Protected Instance
- Detaching a Replication Pair from a Protected Instance
- Adding an NIC to a Protected Instance
- Deleting an NIC from a Protected Instance
- Modifying the Specifications of a Protected Instance
- Batch Creating Protected Instances
- Batch Deleting Protected Instances
- Replication Pair
- DR Drill
- Tag Management
- Task Center
- Tenant Quota Management
- Appendixes
- Change History
- SDK Reference
- Common Problems
Synchronous Replication (for Installed Base Operations)
- Do I Need to Manually Create DR Resources?
- What Can I Do When the EIP Cannot Be Pinged After I Perform a Switchover for a Protection Group Containing a SUSE Server?
- What Can I Do If the NIC Names of the DR Drill Server and Production Site Server Are Different?
- What Can I Do If hostname of the Production Site Server and DR Site Server Are Different After a Switchover or Failover?
- Why NICs of DR Site Servers Are Not Displayed After I Perform a Failover?
- What Are the Precautions If the Production Site Server Uses the Key Login Mode?
- What Should I Pay Attention to When Logging In to the Server After the First Time Ever I Executed a Switchover, Failover, or DR Drill?
- How Do I Use a Resource Package?
- How Do I Handle the drm Process Start Failure?
- Failed to Install and Configure Disaster Recovery Gateway When Process drm Exists But Port 7443 Is Not Listened
- What Can I Do If the Name of a Production Site Server or the Host Name Reported by the Gateway Is Incorrect and Always Displayed as "localhost"?
- What Can I Do If the Disaster Recovery Site VM Is Not Started After a Switchover?
- How Do I Obtain the Installation Package on a Production Site Server from the Gateway?
- How Do I Enable or Disable an ECS Firewall and Add a Port Exception to the Firewall?
- Why Can't I Find the Disaster Recovery Gateway When Associating a Replica Pair with It?
- Why Is No Production Site Server Displayed When I Create Protected Instances?
- Videos
- Glossary
- Best Practices
Batch Upgrading Proxy Clients
- The disaster recovery gateway has been installed. For Linux clients, the gateway version must be 24.6.0 or later. For Windows clients, the gateway version must be 24.9.0 or later.
- Proxy clients have been installed on target production site servers. For Linux clients, the client version must be 24.6.0 or later. For Windows clients, the client version must be 24.9.0 or later.
- Before upgrading the proxy client on a Linux server, run getenforce to check the SELinux mode. If the mode is Enforcing, change it to Disabled or Permissive. After the upgrade is complete, restore the SELinux setting.
Notes and constraints
Batch upgrading proxy clients on both Windows and Linux servers using one command is currently not supported.
In the following example, sdrs_xxxx_24.9.0.xxxx.tar.gz is the proxy client package (24.9.0) used for illustration.
- Obtain the proxy client package sdrs_xxxx_24.9.0.xxxx.tar.gz from the gateway server.
- Run the following command as user root to upgrade proxy clients in batches:
/opt/cloud/sdrs/sidecar/script/cmd_tools.sh upgrade --ip=ip_list --package=package_path --timeout=cmd_timeout_in_s
Parameter description:
--ip: The private IP addresses of the production site servers you want to upgrade proxy clients. Separate multiple IP addresses with commas (,).
--package: The path of the Linux installation package sdrs_xxxx_24.9.0.xxxx.tar.gz.
--timeout: The command timeout interval, in seconds. The default value is 300. You are advised to set the timeout interval based on the number of production site servers. The formula is as follows: Number of production site servers x 200 (The time required for upgrading a proxy client. Use 300 for the client on a Windows server.)
A complete example command is as follows:
/opt/cloud/sdrs/sidecar/script/cmd_tools.sh upgrade --ip=192.168.0.6,192.168.0.188,192.168.0.204 --package=sdrs_xxxx_24.9.0.xxxx.tar.gz --timeout=600
- Enter y to continue the upgrade if the confirmation information is displayed.
- Check the command output. If "upgrade SDRS successfully" is returned, the proxy client is successfully upgraded on all production site servers.
