- What's New
- Product Bulletin
- Getting Started
User Guide
- Permissions Management
Asynchronous Replication
- Managing a Replica Pair
- Managing a Protection Group
- Managing Protected Instances
- Managing DR Drills
- Managing Clients
- Synchronous Replication Management (for Installed Base Operations)
- Appendixes
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
SDRS APIs
- Job
- API Version
- Active-Active Domain
Protection Group
- Creating a Protection Group
- Querying Protection Groups
- Querying the Details of a Protection Group
- Deleting a Protection Group
- Changing the Name of a Protection Group
- Enabling Protection or Enabling Protection Again for a Protection Group
- Disabling Protection for a Protection Group
- Performing a Failover for a Protection Group
- Performing a Planned Failover for a Protection Group
Protected Instance
- Creating a Protected Instance
- Deleting a Protected Instance
- Querying Protected Instances
- Querying Details About a Protected Instance
- Changing the Name of a Protected Instance
- Attaching a Replication Pair to a Protected Instance
- Detaching a Replication Pair from a Protected Instance
- Adding an NIC to a Protected Instance
- Deleting an NIC from a Protected Instance
- Modifying the Specifications of a Protected Instance
- Batch Creating Protected Instances
- Batch Deleting Protected Instances
- Replication Pair
- DR Drill
- Tag Management
- Task Center
- Tenant Quota Management
- Appendixes
- Change History
- SDK Reference
- Common Problems
Synchronous Replication (for Installed Base Operations)
- Do I Need to Manually Create DR Resources?
- What Can I Do When the EIP Cannot Be Pinged After I Perform a Switchover for a Protection Group Containing a SUSE Server?
- What Can I Do If the NIC Names of the DR Drill Server and Production Site Server Are Different?
- What Can I Do If hostname of the Production Site Server and DR Site Server Are Different After a Switchover or Failover?
- Why NICs of DR Site Servers Are Not Displayed After I Perform a Failover?
- What Are the Precautions If the Production Site Server Uses the Key Login Mode?
- What Should I Pay Attention to When Logging In to the Server After the First Time Ever I Executed a Switchover, Failover, or DR Drill?
- How Do I Use a Resource Package?
- How Do I Handle the drm Process Start Failure?
- Failed to Install and Configure Disaster Recovery Gateway When Process drm Exists But Port 7443 Is Not Listened
- What Can I Do If the Name of a Production Site Server or the Host Name Reported by the Gateway Is Incorrect and Always Displayed as "localhost"?
- What Can I Do If the Disaster Recovery Site VM Is Not Started After a Switchover?
- How Do I Obtain the Installation Package on a Production Site Server from the Gateway?
- How Do I Enable or Disable an ECS Firewall and Add a Port Exception to the Firewall?
- Why Can't I Find the Disaster Recovery Gateway When Associating a Replica Pair with It?
- Why Is No Production Site Server Displayed When I Create Protected Instances?
- Videos
- Glossary
- Best Practices
Batch Installing Linux Proxy Clients
- It is recommended that you deploy the disaster recovery gateway and proxy client in the same security group and only allow ECSs within the security group to communication with each other. For details, see Security Group Configuration Examples.
- Ensure that the ports listed in Port Description (Asynchronous Replication) are not used.
- If the firewall is enabled on the ECS where you want to deploy the proxy client, enable port 59526 on the firewall.
- The disaster recovery gateway of 24.6.0 or later has been installed.
- The usernames, passwords, and port numbers used for logging in to the production site servers have been obtained. Ensure that all of the production site servers run Linux.
- The network between the gateway server and production site servers is connected. Remote login using SSH is available.
- The expect command is installed and supported on the gateway server.
In the following example, sdrs_xxxx_24.9.0.xxxx.tar.gz is the proxy client package (24.9.0) used for illustration.
- Remotely log in to the gateway server and run the following command to check whether the expect command is available. If not, configure the yum source and obtain and install the command first.
/bin/expect -v
- Generate the Linux installation package sdrs_xxxx_24.9.0.xxxx.tar.gz_with_certs.tar.gz including the certificate file on the gateway server. For details, see section "Installing a Proxy Client."
- Use the following command to create the linux-host-list.txt file and add the private IP addresses, login ports, usernames, and passwords of the production site servers to the file.
Command format:
echo "IP address Port user userPassword rootPassword drmIp hostagentIp" >> linux-host-list.txt
Parameter description:
IP address: The IP address of the production site server used for remote login.
Port: The port for remote login.
user: The username for remote login.
userPassword: The password for remote login. If root is used for login, use the rootPassword value for userPassword.
rootPassword: The password of the root user.
drmIp: The IP address of the gateway server.
hostagentIp: The IP address of the primary NIC on the production site server.
A complete example command is as follows:
echo "192.168.0.1 22 user userPassword rootPassword 192.168.0.10 192.168.0.1" >> linux-host-list.txt
To add information of multiple production site servers, separate the information of each server with a line separator.
Example:
echo "192.168.0.6 22 user userPassword rootPassword 192.168.0.202 192.168.0.6" >> linux-host-list.txt echo "192.168.0.188 22 user userPassword rootPassword 192.168.0.202 192.168.0.188" >> linux-host-list.txt echo "192.168.0.204 22 user userPassword rootPassword 192.168.0.202 192.168.0.204" >> linux-host-list.txt
- Check whether all of the information is added.
cat linux-host-list.txt
- Run the following command as user root to install proxy clients in a batch:
/opt/cloud/sdrs/sidecar/script/cmd_tools.sh install --host-list=host_list_file_path --package=package_path --timeout=cmd_timeout_in_s
--host-list: The path of the linux-host-list.txt file.
--package: The path of the Linux installation package sdrs_xxxx_24.9.0.xxxx.tar.gz_with_certs.tar.gz.
--timeout: The command timeout interval, in seconds. The default value is 300. You are advised to set the timeout interval based on the number of production site servers. The formula is as follows: Number of production site servers x 200 (time required for installing a proxy client)
/opt/cloud/sdrs/sidecar/script/cmd_tools.sh install --host-list=linux-host-list.txt --package=sdrs_xxxx_24.9.0.xxxx.tar.gz_with_certs.tar.gz --timeout=600
- Check the command output. If "install SDRS successfully" is returned, the proxy client is successfully installed on all production site servers.
- Delete the linux-host-list.txt file to prevent password leakage.
rm -rf linux-host-list.txt
Troubleshooting
If "error: install SDRS timeout" is returned, the script execution timed out. Perform the following steps on the gateway server to troubleshoot the fault:
- Check whether the expect command is supported.
/bin/expect -v
- Check the "IP address install successfully" information in the command output for production site servers with proxy client successfully installed. For those whose client installation failed, check whether the usernames and passwords in linux-host-list.txt are correct. Use the following command to check whether a server can be logged in to:
/bin/ssh -t -p Port Username @IP address
