- What's New
- Product Bulletin
- Getting Started
User Guide
- Permissions Management
Asynchronous Replication
- Managing a Replica Pair
- Managing a Protection Group
- Managing Protected Instances
- Managing DR Drills
- Managing Clients
- Synchronous Replication Management (for Installed Base Operations)
- Appendixes
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
SDRS APIs
- Job
- API Version
- Active-Active Domain
Protection Group
- Creating a Protection Group
- Querying Protection Groups
- Querying the Details of a Protection Group
- Deleting a Protection Group
- Changing the Name of a Protection Group
- Enabling Protection or Enabling Protection Again for a Protection Group
- Disabling Protection for a Protection Group
- Performing a Failover for a Protection Group
- Performing a Planned Failover for a Protection Group
Protected Instance
- Creating a Protected Instance
- Deleting a Protected Instance
- Querying Protected Instances
- Querying Details About a Protected Instance
- Changing the Name of a Protected Instance
- Attaching a Replication Pair to a Protected Instance
- Detaching a Replication Pair from a Protected Instance
- Adding an NIC to a Protected Instance
- Deleting an NIC from a Protected Instance
- Modifying the Specifications of a Protected Instance
- Batch Creating Protected Instances
- Batch Deleting Protected Instances
- Replication Pair
- DR Drill
- Tag Management
- Task Center
- Tenant Quota Management
- Appendixes
- Change History
- SDK Reference
- Common Problems
Synchronous Replication (for Installed Base Operations)
- Do I Need to Manually Create DR Resources?
- What Can I Do When the EIP Cannot Be Pinged After I Perform a Switchover for a Protection Group Containing a SUSE Server?
- What Can I Do If the NIC Names of the DR Drill Server and Production Site Server Are Different?
- What Can I Do If hostname of the Production Site Server and DR Site Server Are Different After a Switchover or Failover?
- Why NICs of DR Site Servers Are Not Displayed After I Perform a Failover?
- What Are the Precautions If the Production Site Server Uses the Key Login Mode?
- What Should I Pay Attention to When Logging In to the Server After the First Time Ever I Executed a Switchover, Failover, or DR Drill?
- How Do I Use a Resource Package?
- How Do I Handle the drm Process Start Failure?
- Failed to Install and Configure Disaster Recovery Gateway When Process drm Exists But Port 7443 Is Not Listened
- What Can I Do If the Name of a Production Site Server or the Host Name Reported by the Gateway Is Incorrect and Always Displayed as "localhost"?
- What Can I Do If the Disaster Recovery Site VM Is Not Started After a Switchover?
- How Do I Obtain the Installation Package on a Production Site Server from the Gateway?
- How Do I Enable or Disable an ECS Firewall and Add a Port Exception to the Firewall?
- Why Can't I Find the Disaster Recovery Gateway When Associating a Replica Pair with It?
- Why Is No Production Site Server Displayed When I Create Protected Instances?
- Videos
- Glossary
- Best Practices
Show all
Installing a Disaster Recovery Gateway
To use SDRS, you need to separately deploy the disaster recovery gateway at the production site. Do not deploy the gateway and proxy client on the same server.
The gateway aggregates and compresses I/Os received from production site servers and then transmits them to the disaster recovery site.
- The recommended ECS specifications to deploy the gateway are 8 vCPUs and 16 GB memory. Only Linux is supported. Huawei Cloud EulerOS 2.0 and EulerOS 2.9\2.10 are recommended, or see Supported OSs.
- The region, AZ, and VPC of the gateway ECS must be the same as those of the production site servers.
- It is recommended that you deploy the disaster recovery gateway and proxy client in the same security group and only allow ECSs within the security group to communication with each other. For details, see Security Group Configuration Examples.
- Ensure that the ports listed in Port Description (Asynchronous Replication) are not used.
In the following example, sdrs_xxxx_24.9.0.xxxx.tar.gz is the package (24.9.0) used to install the gateway.
- Obtain the disaster recovery gateway package and upload it to a directory on the target ECS.
- IDC-to-cloud: Click the link on the console to download the package and upload it to the ECS where you want to deploy the gateway.
- Cross-region and Cross-AZ: Copy the command provided on the console, log in to the ECS where you want to deploy the gateway, go to the desired directory, and paste and run the command to obtain the package.
- In the directory containing the package, run the following command as user root to decompress the package:
tar -zxvf sdrs_xxxx_24.9.0.xxxx.tar.gz
- Go to the directory containing the installation script.
cd sdrs_xxxx_24.9.0.xxxx
- Install the gateway.
sh install.sh --drm-ip=drm_ip --dra-ip=dra_ip --role=gateway
In the command, drm_ip and dra_ip are the IP address of the server where the disaster recovery gateway is deployed. You can obtain the IP address from the ECS console, as shown in the following figure.
If the command output contains the following information, the gateway has been installed:... Installed DRM successfully. Installed SDRS successfully. ...
For security concerns, SDRS randomly generates a self-signed certificate for inter-component authentication upon the first installation.
- Check whether the gateway is enabled.
ps -ef | grep java | grep drm
Information similar to the following is displayed:service 2089 1 5 10:25 ? 00:01:12 /opt/cloud/sdrs/drm/tools/jre/bin/java -Djava.security.egd=file:/dev/random -jar /opt/cloud/sdrs/drm/drm-24.9.0.jar --service.kernel.security.scc.config_path=file:/opt/cloud/sdrs/drm/classes/scc --spring.config.location=/opt/cloud/sdrs/drm/classes/application.properties
If the command output contains the drm process, the gateway has been enabled.
- Check whether the gateway listening port is enabled.
netstat -ano | grep 7443
- After the installation is complete, check in the software package directory of the same level that the sdrs_xxxx_24.9.0.xxxx_with_certs.tar.gz installation package with a self-signed certificate and the sdrs_xxxx_24.9.0.xxxx.tar.gz_with_certs_sha256 .sha256 file for integrity verification are generated. Use this installation package to install and deploy the proxy client.
CAUTION:
After the package is installed, configure the gateway by referring to Configuring a Disaster Recovery Gateway.
