- What's New
- Product Bulletin
- Getting Started
User Guide
- Permissions Management
Asynchronous Replication
- Managing a Replica Pair
- Managing a Protection Group
- Managing Protected Instances
- Managing DR Drills
- Managing Clients
- Synchronous Replication Management (for Installed Base Operations)
- Appendixes
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
SDRS APIs
- Job
- API Version
- Active-Active Domain
Protection Group
- Creating a Protection Group
- Querying Protection Groups
- Querying the Details of a Protection Group
- Deleting a Protection Group
- Changing the Name of a Protection Group
- Enabling Protection or Enabling Protection Again for a Protection Group
- Disabling Protection for a Protection Group
- Performing a Failover for a Protection Group
- Performing a Planned Failover for a Protection Group
Protected Instance
- Creating a Protected Instance
- Deleting a Protected Instance
- Querying Protected Instances
- Querying Details About a Protected Instance
- Changing the Name of a Protected Instance
- Attaching a Replication Pair to a Protected Instance
- Detaching a Replication Pair from a Protected Instance
- Adding an NIC to a Protected Instance
- Deleting an NIC from a Protected Instance
- Modifying the Specifications of a Protected Instance
- Batch Creating Protected Instances
- Batch Deleting Protected Instances
- Replication Pair
- DR Drill
- Tag Management
- Task Center
- Tenant Quota Management
- Appendixes
- Change History
- SDK Reference
- Common Problems
Synchronous Replication (for Installed Base Operations)
- Do I Need to Manually Create DR Resources?
- What Can I Do When the EIP Cannot Be Pinged After I Perform a Switchover for a Protection Group Containing a SUSE Server?
- What Can I Do If the NIC Names of the DR Drill Server and Production Site Server Are Different?
- What Can I Do If hostname of the Production Site Server and DR Site Server Are Different After a Switchover or Failover?
- Why NICs of DR Site Servers Are Not Displayed After I Perform a Failover?
- What Are the Precautions If the Production Site Server Uses the Key Login Mode?
- What Should I Pay Attention to When Logging In to the Server After the First Time Ever I Executed a Switchover, Failover, or DR Drill?
- How Do I Use a Resource Package?
- How Do I Handle the drm Process Start Failure?
- Failed to Install and Configure Disaster Recovery Gateway When Process drm Exists But Port 7443 Is Not Listened
- What Can I Do If the Name of a Production Site Server or the Host Name Reported by the Gateway Is Incorrect and Always Displayed as "localhost"?
- What Can I Do If the Disaster Recovery Site VM Is Not Started After a Switchover?
- How Do I Obtain the Installation Package on a Production Site Server from the Gateway?
- How Do I Enable or Disable an ECS Firewall and Add a Port Exception to the Firewall?
- Why Can't I Find the Disaster Recovery Gateway When Associating a Replica Pair with It?
- Why Is No Production Site Server Displayed When I Create Protected Instances?
- Videos
- Glossary
- Best Practices
Disaster recovery site servers are created using the most current data and billed based on the server billing standards. If servers are still running during a failover, the system synchronizes all the server data before failover is performed to the disaster recovery site servers. Data written to the servers during the failover may not be synchronized to the disaster recovery site. If one of the servers to be failed over fails, data on the server may fail to be synchronized and some data may be lost.
After a failover, data is not automatically synchronized from the disaster recovery site to the production site, and protection is disabled for protected instances. To start data synchronization from the disaster recovery site to the production site, perform a reverse reprotection.
- Failover is a high-risk operation. After a failover, services are started at the disaster recovery site. At this time, you must ensure that production site services are stopped. Otherwise, services may be conflicted or interrupted and data may be damaged because both sites are providing services. If you just want to verify and analyze the disaster recovery site data, perform disaster recovery drills instead.
- During a failover in a V2C scenario, an ECS used for system conversion will be created, with a name suffix VMwareToCloud. Do not perform any operation on this ECS. Or, the failover may fail. This ECS will be automatically deleted after the failover is complete.
- If NIC switchover is enabled, after a failover, SDRS automatically stops the production site server and changes the server status to Planned stop. If NIC switchover is disabled, the production site server status remains unchanged before and after a failover.
- After a failover, the production site server stops providing services. Or, new data will be overwritten after a reverse synchronization.
- The protection group contains protected instances.
- Initial synchronization is completed for all the protected instances in the protection group, and the status of protected instances is Synchronization finished or Failover failed.
- Protected instance services are running at the production site.
- All services on production site servers are stopped, and all data has been flushed to disks.
Precautions
During a failover, a primary NIC is configured for each disaster recovery site server. If a production site server uses a secondary NIC, you need to manually bind a secondary NIC for the corresponding disaster recovery site server on the server details page.
- Click Service List and choose Storage > Storage Disaster Recovery Service.
The Storage Disaster Recovery Service page is displayed.
- Choose Asynchronous Replication. In the right pane, locate the replica pair housing the protection group you want to perform a failover and click the number in the Protection Groups column.
The Protection Groups tab page is displayed.
- In the navigation tree, choose the target protection group.
The protection group details page is displayed.
- In the upper right corner of the basic information area, click Execute Failover.
The Execute Failover page is displayed.
- Configure disaster recovery site servers.
- Click Next.
- Confirm the disaster recovery site server information and click Submit.
- The protected instance status changes to Executing failover. After the failover is complete, the status changes to Failover completed.
