- What's New
- Product Bulletin
- Getting Started
User Guide
- Permissions Management
Asynchronous Replication
- Managing a Replica Pair
- Managing a Protection Group
- Managing Protected Instances
- Managing DR Drills
- Managing Clients
- Synchronous Replication Management (for Installed Base Operations)
- Appendixes
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
SDRS APIs
- Job
- API Version
- Active-Active Domain
Protection Group
- Creating a Protection Group
- Querying Protection Groups
- Querying the Details of a Protection Group
- Deleting a Protection Group
- Changing the Name of a Protection Group
- Enabling Protection or Enabling Protection Again for a Protection Group
- Disabling Protection for a Protection Group
- Performing a Failover for a Protection Group
- Performing a Planned Failover for a Protection Group
Protected Instance
- Creating a Protected Instance
- Deleting a Protected Instance
- Querying Protected Instances
- Querying Details About a Protected Instance
- Changing the Name of a Protected Instance
- Attaching a Replication Pair to a Protected Instance
- Detaching a Replication Pair from a Protected Instance
- Adding an NIC to a Protected Instance
- Deleting an NIC from a Protected Instance
- Modifying the Specifications of a Protected Instance
- Batch Creating Protected Instances
- Batch Deleting Protected Instances
- Replication Pair
- DR Drill
- Tag Management
- Task Center
- Tenant Quota Management
- Appendixes
- Change History
- SDK Reference
- Common Problems
Synchronous Replication (for Installed Base Operations)
- Do I Need to Manually Create DR Resources?
- What Can I Do When the EIP Cannot Be Pinged After I Perform a Switchover for a Protection Group Containing a SUSE Server?
- What Can I Do If the NIC Names of the DR Drill Server and Production Site Server Are Different?
- What Can I Do If hostname of the Production Site Server and DR Site Server Are Different After a Switchover or Failover?
- Why NICs of DR Site Servers Are Not Displayed After I Perform a Failover?
- What Are the Precautions If the Production Site Server Uses the Key Login Mode?
- What Should I Pay Attention to When Logging In to the Server After the First Time Ever I Executed a Switchover, Failover, or DR Drill?
- How Do I Use a Resource Package?
- How Do I Handle the drm Process Start Failure?
- Failed to Install and Configure Disaster Recovery Gateway When Process drm Exists But Port 7443 Is Not Listened
- What Can I Do If the Name of a Production Site Server or the Host Name Reported by the Gateway Is Incorrect and Always Displayed as "localhost"?
- What Can I Do If the Disaster Recovery Site VM Is Not Started After a Switchover?
- How Do I Obtain the Installation Package on a Production Site Server from the Gateway?
- How Do I Enable or Disable an ECS Firewall and Add a Port Exception to the Firewall?
- Why Can't I Find the Disaster Recovery Gateway When Associating a Replica Pair with It?
- Why Is No Production Site Server Displayed When I Create Protected Instances?
- Videos
- Glossary
- Best Practices
Show all
SDRS Endpoints
Region Name |
Region ID |
Endpoint |
Protocol |
LA-Mexico City2 |
la-north-2 |
sdrs.la-north-2.myhuaweicloud.com |
HTTPS |
TR-Istanbul |
tr-west-1 |
sdrs.tr-west-1.myhuaweicloud.com |
HTTPS |
LA-Santiago |
la-south-2 |
sdrs.la-south-2.myhuaweicloud.com |
HTTPS |
AP-Bangkok |
ap-southeast-2 |
sdrs.ap-southeast-2.myhuaweicloud.com |
HTTPS |
AP-Singapore |
ap-southeast-3 |
sdrs.ap-southeast-3.myhuaweicloud.com |
HTTPS |
CN North-Beijing4 |
cn-north-4 |
sdrs.cn-north-4.myhuaweicloud.com |
HTTPS |
CN East-Shanghai1 |
cn-east-3 |
sdrs.cn-east-3.myhuaweicloud.com |
HTTPS |
CN South-Guangzhou |
cn-south-1 |
sdrs.cn-south-1.myhuaweicloud.com |
HTTPS |
LA-Sao Paulo1 |
sa-brazil-1 |
sdrs.sa-brazil-1.myhuaweicloud.com |
HTTPS |
CN East-Shanghai2 |
cn-east-2 |
sdrs.cn-east-2.myhuaweicloud.com |
HTTPS |
AF-Johannesburg |
af-south-1 |
sdrs.af-south-1.myhuaweicloud.com |
HTTPS |
