Help Center/ Storage Disaster Recovery Service/ User Guide/ Appendixes/ Configuring Disaster Recovery Site Servers
Updated on 2025-04-28 GMT+08:00
Configure disaster recovery site servers before you perform reverse reprotection for the protected instances on the console.
This operation is only required in 24.6.0 and an earlier version. In 24.9.0 and later versions, the disaster recovery gateway can be automatically configured.
  1. Log in to a disaster recovery site server.
  2. Run the require script to configure the gateway.
    • Linux server:
      sh /opt/cloud/sdrs/register_gateway.sh
    • Windows server:
      Go to the C:\cloud\sdrs directory and double-click register_gateway.bat to run the script.
      Figure 1 Windows configuration script
  3. Configure the script parameters.
    1. Cross-AZ scenario:
      Figure 2 Example configuration in Linux
      Figure 3 Example configuration in Windows
      Table 1 describes the variables in the command.
      Table 1 Parameters for configuring cross-AZ disaster recovery
      Site
      How to Obtain
      Example Value
      Replication
      replicationScene
      Replication scenario. There are three replication scenarios.
      • 0: IDC-to-cloud
      • 1: Cross-AZ
      • 2: Cross-region
      Disaster recovery site on Huawei Cloud
      platform_type
      Platform type
      • 0: Huawei public cloud
      • 1: Huawei private cloud
      0
      sourceProjectId
      Project ID
      Log in to the console and choose My Credentials > API Credentials to view the project ID.
      51af777371904892a49a0c3e3e53de44
      sourceEcs
      ECS endpoint
      Obtain the ECS endpoint by referring to ECS Endpoints.
      sourceEvs
      EVS endpoint
      Obtain the EVS endpoint by referring to EVS Endpoints.
      sourceIamAk
      Access key ID
      Obtain AK/SK by referring to How Do I Obtain an Access Key (AK/SK)?
      sourceIamSk
      Secret access key
      targetProjectId
      Project ID
      0605767cb280d5762fd6c0133d6bea3f
      targetSdrs
      SDRS endpoint
      Obtain the SDRS endpoint by referring to SDRS Endpoints.
      sdrs.cn-east-2.myhuaweicloud.com
      targetIamAk
      Access key ID
      RZSAMHULWKKE71N0XHUT
      targetIamSk
      Secret access key
      K7bXplAT0pEpy4SAiN2fHUwEtxvgmK3IqyhqnMTA
    2. Cross-region scenario:
      Table 2 Parameters for configuring cross-region disaster recovery
      How to Obtain
      Example Value
      DR Scene
      Replication
      • 0: IDC-to-cloud
      • 1: Cross-AZ
      • 2: Cross-region
      2
      source/target platform type
      Type of the disaster recovery site
      0
      source/target project id
      Project ID of the region where the disaster recovery site server resides
      source region code
      Destination region ID
      source ecs endpoint
      ECS endpoint in the region where the disaster recovery site server resides
      source evs endpoint
      EVS endpoint in the region where the disaster recovery site server resides
      source/target iam ak
      Access key ID of the region where the disaster recovery site server resides
      source/target iam sk
      Secret access key of the region where the disaster recovery site server resides
      target sdrs endpoint
      SDRS endpoint in the region where the disaster recovery site server resides
  4. Configure the gateway for the proxy client on the disaster recovery site server:
    1. Linux disaster recovery server:
      su - service -c "/opt/cloud/sdrs/hostagent/bin/agent_config.sh --drm-ip=127.0.0.1 --ha-ip=127.0.0.1"
    2. Windows disaster recovery server:
      Open the cmd window and run the following command:
      C:\cloud\sdrs\hostagent\bin\agent_config.bat --drm-ip=127.0.0.1 --ha-ip=127.0.0.1
