Help Center/
Business Recovery Service/
User Guide/
Appendixes/
Changing the Password of User rdadmin
Updated on 2025-04-28 GMT+08:00
- To improve O&M security, you are advised to change the user rdadmin's password of the client OS regularly and disable this user's remote login permission.
- In Linux, user rdadmin does not have a password.
- This section describes how to change the password of user rdadmin in Windows 2016. Change the password according to actual situation in other versions.
- The username and password for logging in to the console have been obtained.
- The username and password for logging in to a Windows ECS have been obtained.
- Go to the ECS console and log in to the Windows ECS.
- Choose Start > Control Panel. In the Control Panel window, click User Accounts.
- Click User Accounts to open the User Account Control dialog box. Select rdadmin and click Reset Password.
- Enter the new password and click OK.
- In Task Manager, click the Services tab and then click Open Service.
- Select RdMonitor and RdNginx respectively. In the displayed dialog box, select Login, change the password to the one entered in 4, and click OK.
Parent topic: Appendixes
