Configuring the HA Function for SAP NetWeaver (Distributed HA Deployment)
To prevent the SAP NetWeaver from being affected by a single point of failure and improve the availability of the SAP NetWeaver, configure HA for the active and standby ASCS nodes of SAP NetWeaver. This operation is required only in the distributed HA deployment scenario.
- The mutual trust relationship has been established between the active and standby ASCS nodes.
- You have disabled the firewall of the OS. For details, see section Modifying OS Configurations.
- To ensure that the communication between the active and standby ASCS nodes is normal, add the mapping between the virtual IP addresses and virtual hostnames to the hosts file after installing the SAP NetWeaver instance.
- Log in to the active and standby ASCS nodes one by one and modify the /etc/hosts file:
vi /etc/hosts
- Change the IP addresses corresponding to the virtual hostnames to the virtual IP addresses.
10.0.3.52 netweaver-0001 10.0.3.196 netweaver-0002 10.0.3.220 ascsha 10.0.3.2 ersha
ascsha indicates the virtual hostname of the active ASCS node and ersha indicates the virtual hostname of the standby ASCS node. Virtual hostnames can be customized.
- Check that both the active and standby ASCS nodes have the /var/log/cluster directory. If the directory does not exist, create one.
- Update the SAP resource-agents package on the active and standby ASCS nodes.
- Run the following command to check whether the resource-agents package has been installed:
sudo grep 'parameter name="IS_ERS"' /usr/lib/ocf/resource.d/heartbeat/SAPInstance
- If the following information is displayed, the patch package has been installed. No further action is required.
- If the following information is not displayed, install the patch package. Go to 2.
<parameter name="IS_ERS" unique="0" required="0">
- Install the resource-agents package.
If the image is SLES 12 SP1, run the following command:
sudo zypper in -t patch SUSE-SLE-HA-12-SP1-2017-885=1
If the image is SLES 12 SP2, run the following command:
sudo zypper in -t patch SUSE-SLE-HA-12-SP2-2018-1923=1
If the image is SLES 12 SP3, run the following command:
sudo zypper in -t patch SUSE-SLE-HA-12-SP3-2018-1922=1
- Update the sap_suse_cluster_connector package on the active and standby ASCS nodes.
- Ensure that the dependency packages patterns-ha-ha_sles and sap-suse-cluster-connector have been installed.
Run the following commands to check whether the dependency packages have been installed:
rpm -qa | grep patterns-ha-ha_sles
rpm -qa | grep sap-suse-cluster-connector
If no, run the following commands:
zypper in -y patterns-ha-ha_sles
zypper in -y sap-suse-cluster-connector
- Log in to the ASCS instance node, obtain the ha_auto_script.zip package, and decompress it to any directory.
- Obtain the ha_auto_script.zip package.
CN-Hong Kong: wget https://obs-sap-ap-southeast-1.obs.ap-southeast-1.myhuaweicloud.com/ha_auto_script/ha_auto_script.zip -P /sapmnt
AP-Bangkok: wget https://obs-sap-ap-southeast-2.obs.ap-southeast-2.myhuaweicloud.com/ha_auto_script/ha_auto_script.zip -P /sapmnt
AF-Johannesburg: wget https://obs-sap-af-south-1.obs.af-south-1.myhuaweicloud.com/ha_auto_script/ha_auto_script.zip -P /sapmnt
LA-Santiago: wget https://obs-sap-la-south-2.obs.la-south-2.myhuaweicloud.com/ha_auto_script/ha_auto_script.zip -P /sapmnt
LA-Sao Paulo1: wget https://obs-sap-sa-brazil-11.obs.sa-brazil-1.myhuaweicloud.com/ha_auto_script/ha_auto_script.zip -P /sapmnt
LA-Mexico City1: wget https://obs-sap-na-mexico-1.obs.na-mexico-1.myhuaweicloud.com/ha_auto_script/ha_auto_script.zip -P /sapmnt
LA-Mexico City2: wget https://obs-sap-la-north-2.obs.la-north-2.myhuaweicloud.com/ha_auto_script/ha_auto_script.zip -P /sapmnt
- Run the following commands to decompress the package:
cd /sapmnt
unzip ha_auto_script.zip
- Set parameters in the ascs_ha.cfg file based on the site requirements. Table 1 describes the parameters in the file.
Table 1 Parameters in the ascs_ha.cfg file Type
Name
masterNode
masterName
ASCS instance node name
masterHeartbeatIP1
Heartbeat plane IP address 1 of the ASCS instance node
masterHeartbeatIP2
Service plane IP address of the ASCS instance node
slaveNode
slaveName
ERS instance node name
slaveHeartbeatIP1
Heartbeat plane IP address 1 of the ERS instance node
slaveHeartbeatIP2
Service plane IP address of the ERS instance node
ASCSInstance
ASCSFloatIP
Service IP address of the ASCS instance node
ASCSInstanceDir
Directory of the ASCS instance
ASCSDevice
Disk partition used by the ASCS instance directory
ASCSProfile
Profile file of the ASCS instance
ERSInstance
NOTE:You need to log in to the ERS instance node to obtain the information about ERSInstanceDir, ERSDevice, and ERSProfile parameters.
ERSFloatIP
Service IP address of the ERS instance node
ERSInstanceDir
Directory of the ERS instance
ERSDevice
Disk partition used by the ERS instance directory
ERSProfile
Profile file of the ERS instance
trunkInfo
SBDDevice
Disk partition used by the SBD. A maximum of three disk partitions are supported. Every two partitions are separated by a comma (,), for example, /dev/sda, /dev/sdb, /dev/sdc.
- Run the following command to perform automatic HA deployment:
sh ascs_auto_ha.sh
- Run the crm status command to check the resource status.
After the HA function is configured, HAE manages resources. Do not start or stop resources in other modes. If you need to manually perform test or modification operations, switch the cluster to the maintenance mode first.
crm configure property maintenance-mode=true
Exit the maintenance mode after the modification is complete.
crm configure property maintenance-mode=false
If you need to stop or restart the node, manually stop the cluster service.
systemctl stop pacemaker
After the ECS is started or restarted, run the following command to start the cluster service:
systemctl start pacemaker
