- What's New
- SAP on Cloud Technology Poster
- SAP Deployment Guide
- Data Provider for SAP User Guide
- SAP HA and DR Guide
- SAP Security White Paper
- SAP HANA Overview
SAP HANA User Guide (Single Node)
- Introduction
Deployment
- Scheme
- Data Planning
- Preparing Resources
- Creating ECSs
- Installing SAP HANA (Single-Node Deployment Without HA Required)
Installing SAP HANA (Single-Node Deployment with HA Required)
- Formatting a Disk
- Installing the SAP HANA Software
- Installing the SAP HANA Studio on a Windows ECS
- Installing the SAP HANA Studio on a Linux ECS
- Connecting SAP HANA Nodes to the SAP HANA Studio
- Configuring the Backup Path
- Configuring the System Replication
- Configuring HA on SAP HANA Nodes
- Configuring SAP HANA Storage Parameters
- Installing Data Provider
- Configuring iSCSI (Cross-AZ HA Deployment)
- Management and Monitoring
- Backing Up and Restoring Data
- FAQs
- Appendix
- Change History
- SAP HANA HA and DR Guide
- SAP NetWeaver User Guide
SAP Application AS User Guide
- Overview
- Deployment
- SAP Application AS Management
- What Is SAP Application AS?
- What Are the Advantages of SAP Application AS?
- What Are Restrictions on Using SAP Application AS?
- How Many AS Policies and AS Configurations Can I Create and Use?
- How Many AS Policies Can Be Enabled?
- How Can I View the Logs of SAP Application AS?
- How Do I Change the CPU Threshold?
- Change History
- SAP S/4HANA Quick Deployment Guide
- SAP S/4HANA HA Deployment Guide
- SAP Business One User Guide
- SAP Business One Quick Deployment Guide
Best Practices
- SAP Best Practices
- Huawei Cloud SAP on DB2 Installation Best Practice
- Huawei Cloud SAP on SQL Server Installation Best Practice
SAP S/4HANA (1809) HA Deployment Best Practice
- Overview
- Preparations
- Resource Planning
- Resource Creation
- Software Installation
- High Availability Configuration
- Change History
- HUAWEI CLOUD SAP Business One on HANA Installation Best Practice
SAP Monitoring Best Practices
- Overview
Installing the Monitoring Agent
- SAP HANA (Single-Node Deployment Without High Availability Required)
- SAP HANA (Single-Node Deployment With High Availability Required)
- SAP S/4HANA (Single-Node Deployment Without High Availability Required)
- SAP S/4HANA (Single-Node Deployment With High Availability Required)
- SAP S/4HANA (Distributed Deployment with High Availability Required)
- SAP S/4HANA (Distributed Deployment Without High Availability Required)
- SAP ECC
- (Optional) Upgrading the Monitoring Agent
- Viewing Monitoring Metrics
- Configuring Grafana SAP Full Screen Monitoring
- Alarm Configuration
- FAQs
- Best Practices of SAP Migration to HUAWEI CLOUD
- Best Practice of Using Block-Level Migration of SMS to Migrate SAP Applications and Databases Running on Linux Servers
- Best Practice of SAP Migration from XEN to KVM
- Best Practice of SAP Disaster Recovery with SDRS
- Best Practice of Rsync-based SAP Disaster Recovery
- SAP Backint Installation Guide
- Best Practices for Uploading SAP Backups to the OBS Bucket
- Best Practices of the SAP ASE Solution
- Best Practices of SAP System Capacity Expansion
- Change History
- Basic Concepts
Purchase
- Why Do I Deploy SAP System on the Cloud?
- What Are the Advantages of Huawei SAP on Cloud Solution?
- What SAP Products Does Huawei SAP on Cloud Solution Support?
- Can I Migrate Local SAP Resources Directly to the Cloud?
- Which Billing Mode Should I Choose When Buying SAP Systems on HUAWEI CLOUD?
- Is SAP Hybris Supported?
- How Do I Ensure the Security of SAP Systems Deployed on HUAWEI CLOUD?
- What Are the Advantages of Deploying SAP HANA on HUAWEI CLOUD?
- What Are the Scenarios Supported by Huawei SAP on Cloud Solution?
- Does HUAWEI CLOUD Sell SAP Software Licenses?
- How Do I Use SAP Software Licenses on HUAWEI CLOUD?
- What Are the Application Scenarios of SAP HANA?
- What OSs Can Be Used by SAP Products on HUAWEI CLOUD?
- Can I Deploy SAP Software on HUAWEI CLOUD Immediately Just After Buying It?
- Can I Migrate SAP Systems on Other Clouds to HUAWEI CLOUD?
Products
- What SAP HANA Products Does HUAWEI CLOUD Provide?
- What HANA ECSs Does HUAWEI CLOUD Provide?
- What SAP NetWeaver ECSs Does HUAWEI CLOUD Provide?
- How Do I Deploy SAP NetWeaver on HUAWEI CLOUD?
- How Do I Deploy SAP HANA on HUAWEI CLOUD?
- How Do I Back Up and Restore SAP HANA?
- How Do I Deploy HA and DR Systems?
- How Can I Migrate an Existing SAP System to HUAWEI CLOUD?
- How Can I Do Sizing?
- What Modules Does a Typical SAP System Contain?
- How Many SAP Systems are Required to Support Services?
- How Do I Back Up SAP Systems and the HANA Database on HUAWEI CLOUD?
- How Do I Connect to the SAP System on HUAWEI CLOUD?
- Change History
- Videos
- Glossary
Show all
Attaching an SFS Turbo File System to an ECS
In distributed deployment and distributed HA deployment scenarios, the created SFS Turbo file system need to be attached to the ECS. This section describes how to attach the SFS Turbo file system in the distributed HA deployment scenario. For details, see Table 4.
- You have created a file system and have obtained the shared path of the file system.
- The IP addresses of the DNS server used to resolve the file system domain name have been configured on the ECS.
- Use PuTTY to log in to the NAT server with an EIP bound. Ensure that user root and the key file (.ppk file) are used for authentication. Then, use SSH to switch to the active ASCS node.
- Run the following command to check whether the NFS software package has been installed:
rpm -qa|grep nfs
- If the package has not been installed, run the following command:
zypper install nfs-client
- Run the following command to check whether the domain name in the file system shared path can be resolved:
nslookup File system domain name
- Run the following command to create a local path for attaching the file system based on Table 4:
mkdirLocal path
For example, run the command mkdir /sapmnt.
- Run the following command to attach the file system to the active ASCS node. Repeat this operation to attach three file systems to the active ASCS node.
mount -t nfs Shared path Local path
- Run the following command to view the attached file systems:
mount -l
- Log in to the standby ASCS node as user root. Repeat steps 2 to 7 to attach the three file systems to the standby ASCS node.
- Write the disk attaching information to the /etc/fstab file so that disks can be automatically attached when the VM is restarted.
vi /etc/fstab
- Enter the path information.
Enter the path based on the actual condition.
- The /etc/fstab format is Disk ID or partition Attached directory Disk format defaults 0 0.
- In the preceding format, The recommended value of the last field fs_passno is 0. In this case, the disk can be attached to the other instance if required.
- Do not write the attaching information of partitions sdb and sdc to the fstab file because the two partitions will be automatically attached when the HA function of SAP NetWeaver is configured. Otherwise, the VM may fail to be restarted. Write the attaching information of other partitions to the fstab file.
An example is provided as follows:
Shared path /sapmnt nfs defaults 0 0 Shared path /usr/sap/A01/SYS nfs defaults 0 0 Shared path /sapcd nfs defaults 0 0
Save the changes and exit.
