- What's New
- SAP on Cloud Technology Poster
- SAP Deployment Guide
- Data Provider for SAP User Guide
- SAP HA and DR Guide
- SAP Security White Paper
- SAP HANA Overview
SAP HANA User Guide (Single Node)
- Introduction
Deployment
- Scheme
- Data Planning
- Preparing Resources
- Creating ECSs
- Installing SAP HANA (Single-Node Deployment Without HA Required)
Installing SAP HANA (Single-Node Deployment with HA Required)
- Formatting a Disk
- Installing the SAP HANA Software
- Installing the SAP HANA Studio on a Windows ECS
- Installing the SAP HANA Studio on a Linux ECS
- Connecting SAP HANA Nodes to the SAP HANA Studio
- Configuring the Backup Path
- Configuring the System Replication
- Configuring HA on SAP HANA Nodes
- Configuring SAP HANA Storage Parameters
- Installing Data Provider
- Configuring iSCSI (Cross-AZ HA Deployment)
- Management and Monitoring
- Backing Up and Restoring Data
- FAQs
- Appendix
- Change History
- SAP HANA HA and DR Guide
- SAP NetWeaver User Guide
SAP Application AS User Guide
- Overview
- Deployment
- SAP Application AS Management
- What Is SAP Application AS?
- What Are the Advantages of SAP Application AS?
- What Are Restrictions on Using SAP Application AS?
- How Many AS Policies and AS Configurations Can I Create and Use?
- How Many AS Policies Can Be Enabled?
- How Can I View the Logs of SAP Application AS?
- How Do I Change the CPU Threshold?
- Change History
- SAP S/4HANA Quick Deployment Guide
- SAP S/4HANA HA Deployment Guide
- SAP Business One User Guide
- SAP Business One Quick Deployment Guide
Best Practices
- SAP Best Practices
- Huawei Cloud SAP on DB2 Installation Best Practice
- Huawei Cloud SAP on SQL Server Installation Best Practice
SAP S/4HANA (1809) HA Deployment Best Practice
- Overview
- Preparations
- Resource Planning
- Resource Creation
- Software Installation
- High Availability Configuration
- Change History
- HUAWEI CLOUD SAP Business One on HANA Installation Best Practice
SAP Monitoring Best Practices
- Overview
Installing the Monitoring Agent
- SAP HANA (Single-Node Deployment Without High Availability Required)
- SAP HANA (Single-Node Deployment With High Availability Required)
- SAP S/4HANA (Single-Node Deployment Without High Availability Required)
- SAP S/4HANA (Single-Node Deployment With High Availability Required)
- SAP S/4HANA (Distributed Deployment with High Availability Required)
- SAP S/4HANA (Distributed Deployment Without High Availability Required)
- SAP ECC
- (Optional) Upgrading the Monitoring Agent
- Viewing Monitoring Metrics
- Configuring Grafana SAP Full Screen Monitoring
- Alarm Configuration
- FAQs
- Best Practices of SAP Migration to HUAWEI CLOUD
- Best Practice of Using Block-Level Migration of SMS to Migrate SAP Applications and Databases Running on Linux Servers
- Best Practice of SAP Migration from XEN to KVM
- Best Practice of SAP Disaster Recovery with SDRS
- Best Practice of Rsync-based SAP Disaster Recovery
- SAP Backint Installation Guide
- Best Practices for Uploading SAP Backups to the OBS Bucket
- Best Practices of the SAP ASE Solution
- Best Practices of SAP System Capacity Expansion
- Change History
- Basic Concepts
Purchase
- Why Do I Deploy SAP System on the Cloud?
- What Are the Advantages of Huawei SAP on Cloud Solution?
- What SAP Products Does Huawei SAP on Cloud Solution Support?
- Can I Migrate Local SAP Resources Directly to the Cloud?
- Which Billing Mode Should I Choose When Buying SAP Systems on HUAWEI CLOUD?
- Is SAP Hybris Supported?
- How Do I Ensure the Security of SAP Systems Deployed on HUAWEI CLOUD?
- What Are the Advantages of Deploying SAP HANA on HUAWEI CLOUD?
- What Are the Scenarios Supported by Huawei SAP on Cloud Solution?
- Does HUAWEI CLOUD Sell SAP Software Licenses?
- How Do I Use SAP Software Licenses on HUAWEI CLOUD?
- What Are the Application Scenarios of SAP HANA?
- What OSs Can Be Used by SAP Products on HUAWEI CLOUD?
- Can I Deploy SAP Software on HUAWEI CLOUD Immediately Just After Buying It?
- Can I Migrate SAP Systems on Other Clouds to HUAWEI CLOUD?
Products
- What SAP HANA Products Does HUAWEI CLOUD Provide?
- What HANA ECSs Does HUAWEI CLOUD Provide?
- What SAP NetWeaver ECSs Does HUAWEI CLOUD Provide?
- How Do I Deploy SAP NetWeaver on HUAWEI CLOUD?
- How Do I Deploy SAP HANA on HUAWEI CLOUD?
- How Do I Back Up and Restore SAP HANA?
- How Do I Deploy HA and DR Systems?
- How Can I Migrate an Existing SAP System to HUAWEI CLOUD?
- How Can I Do Sizing?
- What Modules Does a Typical SAP System Contain?
- How Many SAP Systems are Required to Support Services?
- How Do I Back Up SAP Systems and the HANA Database on HUAWEI CLOUD?
- How Do I Connect to the SAP System on HUAWEI CLOUD?
- Change History
- Videos
- Glossary
Applying for a VPC
All SAP NetWeaver ECSs must be in the same VPC. Therefore, you must apply a VPC for an SAP NetWeaver system and specify the subnet segment for the VPC.
- Log in to the public cloud management console.
- In the navigation pane on the left, click
and choose Network > Virtual Private Cloud.
- Click Create VPC on the right of the page.
- On the Create VPC page, configure VPC parameters.
The parameters are as follows:
Basic Information- Name: specifies the VPC name.
- CIDR Block: specifies the IP address range for the VPC. The subnet IP address range in the VPC must be within this IP address range. Configure the VPC IP address range, for example, 10.0.0.0/8, based on the subnet information in sections Network Plane Planning and Security Group Planning.
- Enterprise Project: If an enterprise project has been created, you can add the VPC to an enabled enterprise project. For example, SAP.
Enterprise project management allows users to manage cloud resources based on enterprise projects. This helps you manage resources and personnel in your projects.
For details about creating and managing enterprise projects, see the Enterprise Management User Guide.
- Tag: specifies the VPC tag, which consists of a key and value pair. This parameter is optional.
Default Subnet- AZ: specifies the AZ of the VPC subnet.
- Name: specifies the name of the default VPC subnet. You are recommended to set this parameter value to the name of the service or client plane subnet, for example, 10.0.3.x.
- CIDR Block: specifies the IP address range for the default VPC subnet. Ensure that the IP address range for the default VPC subnet is within the IP address range for the VPC subnet. Configure this parameter based on the deployment plan described in sections Network Plane Planning and Security Group Planning.
- Gateway: specifies the gateway IP address of the subnet.
- Advanced Settings: If you set it to Custom, you need to configure the following parameters:
- DNS Server Address: An external DNS server address is used by default. If you need to change the DNS server address, ensure that the DNS server addresses you configured are available.
- Click Create Now.
