- What's New
- SAP on Cloud Technology Poster
- SAP Deployment Guide
- Data Provider for SAP User Guide
- SAP HA and DR Guide
- SAP Security White Paper
- SAP HANA Overview
SAP HANA User Guide (Single Node)
- Introduction
Deployment
- Scheme
- Data Planning
- Preparing Resources
- Creating ECSs
- Installing SAP HANA (Single-Node Deployment Without HA Required)
Installing SAP HANA (Single-Node Deployment with HA Required)
- Formatting a Disk
- Installing the SAP HANA Software
- Installing the SAP HANA Studio on a Windows ECS
- Installing the SAP HANA Studio on a Linux ECS
- Connecting SAP HANA Nodes to the SAP HANA Studio
- Configuring the Backup Path
- Configuring the System Replication
- Configuring HA on SAP HANA Nodes
- Configuring SAP HANA Storage Parameters
- Installing Data Provider
- Configuring iSCSI (Cross-AZ HA Deployment)
- Management and Monitoring
- Backing Up and Restoring Data
- FAQs
- Appendix
- Change History
- SAP HANA HA and DR Guide
- SAP NetWeaver User Guide
SAP Application AS User Guide
- Overview
- Deployment
- SAP Application AS Management
- What Is SAP Application AS?
- What Are the Advantages of SAP Application AS?
- What Are Restrictions on Using SAP Application AS?
- How Many AS Policies and AS Configurations Can I Create and Use?
- How Many AS Policies Can Be Enabled?
- How Can I View the Logs of SAP Application AS?
- How Do I Change the CPU Threshold?
- Change History
- SAP S/4HANA Quick Deployment Guide
- SAP S/4HANA HA Deployment Guide
- SAP Business One User Guide
- SAP Business One Quick Deployment Guide
Best Practices
- SAP Best Practices
- Huawei Cloud SAP on DB2 Installation Best Practice
- Huawei Cloud SAP on SQL Server Installation Best Practice
SAP S/4HANA (1809) HA Deployment Best Practice
- Overview
- Preparations
- Resource Planning
- Resource Creation
- Software Installation
- High Availability Configuration
- Change History
- HUAWEI CLOUD SAP Business One on HANA Installation Best Practice
SAP Monitoring Best Practices
- Overview
Installing the Monitoring Agent
- SAP HANA (Single-Node Deployment Without High Availability Required)
- SAP HANA (Single-Node Deployment With High Availability Required)
- SAP S/4HANA (Single-Node Deployment Without High Availability Required)
- SAP S/4HANA (Single-Node Deployment With High Availability Required)
- SAP S/4HANA (Distributed Deployment with High Availability Required)
- SAP S/4HANA (Distributed Deployment Without High Availability Required)
- SAP ECC
- (Optional) Upgrading the Monitoring Agent
- Viewing Monitoring Metrics
- Configuring Grafana SAP Full Screen Monitoring
- Alarm Configuration
- FAQs
- Best Practices of SAP Migration to HUAWEI CLOUD
- Best Practice of Using Block-Level Migration of SMS to Migrate SAP Applications and Databases Running on Linux Servers
- Best Practice of SAP Migration from XEN to KVM
- Best Practice of SAP Disaster Recovery with SDRS
- Best Practice of Rsync-based SAP Disaster Recovery
- SAP Backint Installation Guide
- Best Practices for Uploading SAP Backups to the OBS Bucket
- Best Practices of the SAP ASE Solution
- Best Practices of SAP System Capacity Expansion
- Change History
- Basic Concepts
Purchase
- Why Do I Deploy SAP System on the Cloud?
- What Are the Advantages of Huawei SAP on Cloud Solution?
- What SAP Products Does Huawei SAP on Cloud Solution Support?
- Can I Migrate Local SAP Resources Directly to the Cloud?
- Which Billing Mode Should I Choose When Buying SAP Systems on HUAWEI CLOUD?
- Is SAP Hybris Supported?
- How Do I Ensure the Security of SAP Systems Deployed on HUAWEI CLOUD?
- What Are the Advantages of Deploying SAP HANA on HUAWEI CLOUD?
- What Are the Scenarios Supported by Huawei SAP on Cloud Solution?
- Does HUAWEI CLOUD Sell SAP Software Licenses?
- How Do I Use SAP Software Licenses on HUAWEI CLOUD?
- What Are the Application Scenarios of SAP HANA?
- What OSs Can Be Used by SAP Products on HUAWEI CLOUD?
- Can I Deploy SAP Software on HUAWEI CLOUD Immediately Just After Buying It?
- Can I Migrate SAP Systems on Other Clouds to HUAWEI CLOUD?
Products
- What SAP HANA Products Does HUAWEI CLOUD Provide?
- What HANA ECSs Does HUAWEI CLOUD Provide?
- What SAP NetWeaver ECSs Does HUAWEI CLOUD Provide?
- How Do I Deploy SAP NetWeaver on HUAWEI CLOUD?
- How Do I Deploy SAP HANA on HUAWEI CLOUD?
- How Do I Back Up and Restore SAP HANA?
- How Do I Deploy HA and DR Systems?
- How Can I Migrate an Existing SAP System to HUAWEI CLOUD?
- How Can I Do Sizing?
- What Modules Does a Typical SAP System Contain?
- How Many SAP Systems are Required to Support Services?
- How Do I Back Up SAP Systems and the HANA Database on HUAWEI CLOUD?
- How Do I Connect to the SAP System on HUAWEI CLOUD?
- Change History
- Videos
- Glossary
Show all
SAP NetWeaver Instances
The SAP NetWeaver system consists of the following instances in any deployment mode.
- Dialog instance
Dialog instance is optional and installed on separate hosts to ensure high availability of dialog processes. Dialog instance includes:
- Dispatcher
- Work Processes (Dialog, Batch, Spool, and Update)
- Gateway
- Internet Communication Manager (ICM)
- Internet Graphics Service (IGS)
In a cluster scenario, Dialog instance can be added to the cluster. After Dialog instance is added to the cluster, Central instance updates the Dialog instance information. Each cluster requires a load balancing solution, such as SAP Web Dispatcher. Table 1 lists the components contained in Dialog instance.
Table 1 Components contained in Dialog instance Instance
Component
Function
Dialog instance
Work processes are used to execute applications and contain the Dialog, Batch, Spool, and Update processes. Work processes are components that are able to execute an application (that is, each dialog step). Each work process is linked to a memory area containing the context of the application being run. The context contains the current data for the application program. This needs to be available in each dialog step.
Dispatcher
The dispatcher is the link between the work processes and the users logged in to the ABAP application server (that is, the SAP GUIs of these users). Its task is to receive requests for dialog steps from the SAP GUI and direct them to a free work process. In the same way, it directs screen output resulting from the dialog step back to the appropriate user.
Gateway
This is the interface for the communication protocols of NetWeaver AS ABAP (RFC, CPI/C). It can communicate with other ABAP application servers of the same NW AS, with other SAP Systems, or with external non-SAP systems.
The Internet Communication Manager ensures that communication between the SAP system (SAP NetWeaver Application Server) and the outside world via HTTP, HTTPS and SMTP protocols works properly. In its role as a server, the ICM can process requests from the Internet that arrive as URLs with the server/port combination that the ICM can listen to. The ICM then calls the relevant local handler for the URL in question.
IGS is used to generate Web-based graphics from the SAP Web AS.
- ASCS instance
ASCS instance includes the Enqueue and Message servers. An SAP NetWeaver system contains only one ASCS instance. Therefore, ASCS instance must have no single point of failure (SPOF) in the PRD system. To ensure high availability of ASCS instance, you need to install ERS instance.
- Message Server
A Message server is used for communication among Dialog instances and provides information for Dispatcher for load balancing.
- Enqueue Server
An Enqueue server contains a lock table which contains the database lock and the basic lock information configured by Java Server Process. The Enqueue server can also synchronize data among Java clusters. In an AS ABAP case, an Enqueue server processes the locks of data objects.
- ERS instance
An ERS instance ensures high availability for ASCS instance and protects Message Server and Enqueue Server on ASCS instance.
Table 2 lists the components contained in ASCS instance.
Table 2 ASCS instance and its components Instance
Service
Function
ASCS instance
Message server
Message server is an independent process and contained in ASCS instance. One SAP system contains only one Message server. Message Server provides the following functions:
It is the core communication channel between the separated application servers.
It allocates login users using the login group function of SAP GUI and RFC.
It functions as the information center of Web Dispatcher and application servers.
Enqueue Server
Enqueue Server is a special lock mechanism in the SAP system, which prevents a line of data from being simultaneously changed by two processes and ensures consistency in updating the database.
Enqueue Replication Server (ERS)
ERS is used to protect Message and Enqueue servers contained in ASCS instance.
- Message Server
- Web Dispatcher
An SAP Web dispatcher is a link connecting Internet to SAP NetWeaver and locates in the demilitarized zone (DMZ). All HTTP requests pass Web Dispatcher, which ensures connection security. Then Web Dispatcher allocates the requests to multiple SAP NetWeaver application servers.
- Database instance
The Database instance is mandatory in an SAP NetWeaver system and is used to create an ABAP schema for the SAP system in the database.
Other related software includes SAP Host Agent, SWPM, and SAPCAR.
