Updated on 2025-09-04 GMT+08:00
About This Document
The document conventions are as follows:
- This document provides instructions for you to prepare resources (such as ECSs and network resources) on the public cloud platform, and install SAP NetWeaver.
- This document cannot replace the standard SAP document. If you have any trouble in installing and using SAP NetWeaver due to its own problems, contact the SAP technical support.
- This document is written based on the SUSE Linux OS. The deployment modes mentioned in the document are only for reference. Install SAP NetWeaver by referring to the standard SAP installation manual or based on sizing results and site requirements.
- You have installed the SAP HANA database and the SAP HANA database is used as the background database to install SAP NetWeaver.
Parent topic: Overview
