Network Planning
Network Plane Planning
Figure 1 shows the network plane planning in the single node scenario.
The network segments and IP addresses are for reference only.
In this scenario, only one NIC is used for network communication.
Table 1 shows the planned network information.
Parameter |
Description |
Example Value |
IP address of the server/client plane |
Allows an SAP Business One node to communicate with service software or SAP Business One Client software. Allows an SAP HANA node to communicate with service software or SAP HANA Studio client software. |
SAP Business One: 10.0.3.2 SAP Business One Client: 10.0.3.3 SAP HANA Studio: 10.0.3.4 NAT server: 10.0.3.5 |
Elastic IP address |
Allows you to access the SAP HANA Studio and NAT server. |
Automatically allocated |
Security Group Rules
- The network segments and IP addresses are for reference only. The following security group rules are recommended practices. You can configure your own security group rules as needed.
- In the following table, ## stands for the SAP HANA instance ID, such as 00. Ensure that this ID is the same as the instance ID specified when you install the SAP HANA software.
- For more information about specific ports and security group rules to be accessed by SAP, see https://help.sap.com/viewer/575a9f0e56f34c6e8138439eefc32b16/2.0/en-US/616a3c0b1cc748238de9c0341b15c63c.html.
Source |
Protocol |
Port Range |
Description |
Inbound |
10.0.0.0/24 |
TCP |
5##13 to 5##14 |
Allows the SAP HANA Studio to access SAP HANA. |
10.0.0.0/24 |
TCP |
3##15 |
Provides ports for the service plane. |
10.0.0.0/24 |
TCP |
3##17 |
10.0.0.0/24 |
TCP |
22 |
Allows SAP HANA to be accessed using SSH. |
10.0.0.0/24 |
TCP |
43## |
Allows access to XS Engine from the 10.0.0.0/24 subnet using HTTPS. |
10.0.0.0/24 |
TCP |
80## |
Allows access to XS Engine from the 10.0.0.0/24 subnet using HTTP. |
10.0.0.0/24 |
TCP |
8080 (HTTP) |
Allows Software Update Manager (SUM) to access SAP HANA using HTTP. |
10.0.0.0/24 |
TCP |
8443 (HTTPS) |
Allows Software Update Manager (SUM) to access SAP HANA using HTTPS. |
10.0.0.0/24 |
TCP |
1128-1129 |
Allows access to SAP Host Agent using SOAP/HTTP. |
Automatically specified by the system |
ANY |
ANY |
Security group rule created by the system by default It enables ECSs in the same security group to communicate with each other. |
Outbound |
ANY |
ANY |
ANY |
Security group rule created by the system by default Allows SAP HANA to access all peers. |
Source |
Protocol |
Port Range |
Description |
Inbound |
0.0.0.0/0 |
TCP |
3389 |
Allows users to access the SAP HANA Studio using RDP. This rule is required only when the SAP HANA Studio is deployed on a Windows ECS. |
0.0.0.0/0 |
TCP |
22 |
Allows users to access the SAP HANA Studio using SSH. This rule is required only when the SAP HANA Studio is deployed on a Linux ECS. |
ANY |
ANY |
Outbound |
ANY |
ANY |
ANY |
Security group rule created by the system by default Allows SAP HANA Studio to access all peers. |
Source |
Protocol |
Port Range |
Description |
Inbound |
0.0.0.0/0 |
TCP |
22 |
Allows users to access the NAT server using SSH. |
10.0.3.0/24 |
TCP |
80 (HTTP) |
Allows access to instances in the same VPC using HTTP. |
10.0.3.0/24 |
TCP |
443 (HTTPS) |
Allows access to instances in the same VPC using HTTPS. |
ANY |
ANY |
Outbound |
10.0.3.0/24 |
TCP |
22 (SSH) |
Allows the NAT server to access the 10.0.3.0 subnet using SSH. |
0.0.0.0/0 |
TCP |
80 (HTTP) |
Allows instances in a VPC to access any network. |
0.0.0.0/0 |
TCP |
443 (HTTPS) |
