On this page
Show all
Preparing the Configuration File
Updated on 2022-03-04 GMT+08:00
This section describes how to configure parameters in the config.json file. During the installation of SAP application AS and AAS expansion, information in the config.json configuration file will be obtained.
  1. Log in to an ASCS node as user root using a key or password.
  2. On the CLI, download the compressed software package s4autoscaling.zip to the /sapmnt/{sid} directory, for example, /sapmnt/NW0/.
    wget https://obs-sap.cn-east-2.myhuaweicloud.com/autoscaling/s4autoscaling.zip -P /sapmnt/NW0
  3. Run the following command to decompress s4autoscaling.zip:
    unzip s4autoscaling.zip -d /sapmnt/NW0
  4. Run the following command to open the config.json file:
    vi /sapmnt/NW0/autoscaling/config.json
  5. Edit the parameters in the config.json file based on actual requirements. For details, see Table 1.
    Table 1 Parameter description
    Example Value
    SID
    System ID of the SAP S/4HANA system
    NW0
    SchemaPW
    Schema password of the SAP HANA database
    xiaoxiao@123
    MasterPW
    Password configured when installing AAS
    xiaoxiao@123
    SYSTEMPW
    SYSTEM password of the SAP HANA database
    xiaoxiao@123
    SapmntPATH
    sapmnt directory shared to AAS, for example, /sapmnt/{SID}
    10.0.0.41:/sapmnt/NW0
    PASInctanceNR
    PAS instance ID
    01
    Region
    Region where the S/4HANA system resources are located
    cn-south-1
    DDICPasswd
    DDIC user password
    xiaoxiao@123
    LogonGroup
    Name of the created logon group
    tst_group
    InstallVersion
    In the current version, only 1709 is supported. The value must be S4_1709.
    S4_1709
    AASImageID
    Image ID required by AAS ECSs. If this parameter is left blank, use the image that is the same as that of PAS.
    The pip tool must be installed in the image for provisioning AAS ECSs.
    Leave this parameter blank.
    ExistedAASIDs
    • If AASs already exist in the S/4HANA system, set this parameter to, for example, ExistedAASIDs":["981224766","964679324"].
    • If no AAS exists in the S/4HANA system, leave this parameter blank. For example, [].
    AASFlavorID
    Flavor of AAS ECSs. If this parameter is left blank, select the flavor that is the same as that of PASs.
    s1.xlarge
    AgencyName
    Agency name, which must be the same as that of the created agency in section Creating an Agency.
    NW_scaling_agency
    UserName
    HUAWEI CLOUD username
    sap_xiao458925
    DomainName
    HUAWEI CLOUD domain name
    sap_xxx4157666
    IAMEndpoint
    Endpoint address of HUAWEI CLOUD IAM. The value must be iam.myhuaweicloud.com.
    KeypairName
    Name of the key pair used for provisioning AAS ECSs. If this parameter is left blank, use the key pair that is the same as that of PASs. (You can only use key pairs to log in to AASs.)
    Keypair-lf
    ContactPhone
    Phone number of the S/4HANA system administrator, which is used to receive AS information
    188292004xx
    ContactEmail
    Email address of the S/4HANA system administrator, which is used to receive AS information
    1oss.zhang@huawei.com
  6. After the editing is complete, press Esc to exit the editing mode.
  7. Enter :wq and press Enter.
