Creating an Agency
During the installation of AAS, ECSs in SAP application AS group need to obtain the authorization to access HUAWEI CLOUD services. An agency needs to be created in advance. Thus, the agency will be assigned to AAS ECSs automatically during ECS provisioning.
Perform the following operations to create an agency.
- On the management console, click Service List and choose .
- Click in the left pane, and then click Create Agency in the upper right corner. The Create Agency page is displayed.
- Set agency parameters.
- Agency Name: NW_scaling_agency. This name is only for reference.
- Agency Type: Cloud service
- Cloud Service: ECS BMS
- Validity Period: Retain the default setting.
- Permissions: Locate the and in which the target ECS locates and click Modify in the Operation column. On the displayed page, select DNS, KMS, and SMN to configure the permissions for the ECS.
- Click OK to save the agency parameter configuration.
Follow-Up Operations
On the ECS provisioning page, set Agency Name to NW_scaling_agency so that the agency can be used by the ECS.
