Situation Awareness
Situation Awareness
- User Guide
Product Consulting
- What Does SA Do?
- Why Is There No Attack Data or Only A Small Amount of Attack Data?
- What Is the Data Source of Situation Awareness?
- How Do I Get Information About the Most Vulnerable Assets?
- What Are the Dependencies and Differences Between SA and Other Security Services?
- What Are the Differences Between SA and HSS?
- Why Cannot the Total ECS Quota Be Less Than the Number of Existing ECSs?
- Can SA Be Used Across Accounts?
- How Do I Update My Security Score?
- How Do I Handle a Brute-force Attack?
- How Do I Assign Operation Permissions to an Account?
- How Do I Handle the 403 forbidden Error Reported by SA?
- Why Is the Event Data in SA Inconsistent with That in WAF and HSS?
- What Are Differences Between SA and SecMaster?
- Purchase Consulting
- Regions and AZs
Product Consulting
On this page
Show all
Exporting Events
You can export all events with just a few clicks.
The exported Excel file contains Product Name, Company Name, Affected Resources, Category, Severity, Subject, Discovered, Occurrences, Confidence, Importance, and Status.
- When you search events with a filter, a maximum of 10,000 events can be exported.
- Only the events of the last 180 days can be exported.
- SA has received the events from other security products.
- Click
in the upper left corner of the page and choose Security & Compliance > Situation Awareness.
- In the navigation pane on the left, choose Events.
Figure 1 Exporting events
- Filter events.
- Click
to export the filtered events to a .csv file and save it locally.
You can then view them offline.
Parent topic: Events
