Situation Awareness
Situation Awareness
- User Guide
Product Consulting
- What Does SA Do?
- Why Is There No Attack Data or Only A Small Amount of Attack Data?
- What Is the Data Source of Situation Awareness?
- How Do I Get Information About the Most Vulnerable Assets?
- What Are the Dependencies and Differences Between SA and Other Security Services?
- What Are the Differences Between SA and HSS?
- Why Cannot the Total ECS Quota Be Less Than the Number of Existing ECSs?
- Can SA Be Used Across Accounts?
- How Do I Update My Security Score?
- How Do I Handle a Brute-force Attack?
- How Do I Assign Operation Permissions to an Account?
- How Do I Handle the 403 forbidden Error Reported by SA?
- Why Is the Event Data in SA Inconsistent with That in WAF and HSS?
- What Are Differences Between SA and SecMaster?
- Purchase Consulting
- Regions and AZs
Product Consulting
On this page
Show all
Help Center/
Situation Awareness/
User Guide/
Editions/
Selecting a Billing Mode/
Changing the Billing Mode from Pay-per-Use to Yearly/Monthly
- Pay-per-use is a postpaid billing mode. In this mode, your SA is billed by usage duration, and you can enable or disable the SA service at any time.
- Yearly/Monthly is a prepaid billing mode. In this mode, your SA is billed based on required duration. This mode is more cost-effective than the pay-per-use mode and applicable when your resource usage period can be estimated.
If you plan to use SA for a long time, you can change the billing mode to yearly/monthly to save money.
You have purchased the pay-per-use professional edition, including asset quotas.
- Click
in the upper left corner of the page and choose Security & Compliance > Situation Awareness.
- Click Professional in the upper right corner. The edition management window is displayed.
- In the row of purchased quota billed on a pay-per-use basis, click Change to Yearly/Monthly.
- Confirm the resource information and select the required duration.
- Click Pay Now to pay the order
Parent topic: Selecting a Billing Mode
