- User Guide
Product Consulting
- What Does SA Do?
- Why Is There No Attack Data or Only A Small Amount of Attack Data?
- What Is the Data Source of Situation Awareness?
- How Do I Get Information About the Most Vulnerable Assets?
- What Are the Dependencies and Differences Between SA and Other Security Services?
- What Are the Differences Between SA and HSS?
- Why Cannot the Total ECS Quota Be Less Than the Number of Existing ECSs?
- Can SA Be Used Across Accounts?
- How Do I Update My Security Score?
- How Do I Handle a Brute-force Attack?
- How Do I Assign Operation Permissions to an Account?
- How Do I Handle the 403 forbidden Error Reported by SA?
- Why Is the Event Data in SA Inconsistent with That in WAF and HSS?
- What Are Differences Between SA and SecMaster?
- Purchase Consulting
- Regions and AZs
Product Consulting
Show all
DDoS
Overview
In a DDoS attack, an attacker uses compromised computers on the Internet to launch DoS attacks on the target. DoS attacks, also called flood attacks, are intended to exhaust the network or system resources on the target computer, causing services to be interrupted or suspended, so legitimate users are unable to access network services.
The basic, standard, and professional editions can detect more than 100 types of DDoS attacks.
Suggestion
If SA detects that an application system is experiencing a DDoS attack, SA will report an Informational alarm. You are advised to purchase an AAD instance for better protection.
