- User Guide
Product Consulting
- What Does SA Do?
- Why Is There No Attack Data or Only A Small Amount of Attack Data?
- What Is the Data Source of Situation Awareness?
- How Do I Get Information About the Most Vulnerable Assets?
- What Are the Dependencies and Differences Between SA and Other Security Services?
- What Are the Differences Between SA and HSS?
- Why Cannot the Total ECS Quota Be Less Than the Number of Existing ECSs?
- Can SA Be Used Across Accounts?
- How Do I Update My Security Score?
- How Do I Handle a Brute-force Attack?
- How Do I Assign Operation Permissions to an Account?
- How Do I Handle the 403 forbidden Error Reported by SA?
- Why Is the Event Data in SA Inconsistent with That in WAF and HSS?
- What Are Differences Between SA and SecMaster?
- Purchase Consulting
- Regions and AZs
Product Consulting
Show all
Check Settings
This topic describes how to create baseline check plans. To use cloud service baseline inspection, create your check plans first.
- Click
in the upper left corner of the page and choose Security & Compliance > Situation Awareness.
- In the navigation pane on the left, choose Settings > Checks.
Figure 1 Checks
- On the Checks page, select a region for the plan and click Create Plan. The pane for creating a check plan is displayed on the right.
- Configure the check plan.
- Enter the basic information by referring to Table 1.
Table 1 Basic information about a check plan Parameter
Name
Name you specify for the check plan.
Schedule
Select how often and when the check plan is executed.
- Schedule: every day, every 3 days, every 7 days, every 15 days, or every 30 days
- Check triggering time: 00:00-06:00, 06:00-12:00, 12:00-18:00, and 18:00-24:00
- Select a security standard for the plan.
Select the baseline check items to be checked. For details, see Cloud Service Baseline Overview.
- Click OK.
- The check plan is created.
SA will execute the cloud service baseline inspection at the specified time. To view the check result, choose Security & Compliance > Situation Awareness > Baseline Inspection.
