Configuring Recording Callback
You can configure an HTTP/HTTPS URL to receive recording task status callback. SparkRTC will send POST requests to your server, so that you can know the recording task status.
Callback Protocols
- Request: HTTP POST. The request body is in JSON format.
- Response: HTTP STATUS CODE =200. The response body is in JSON format. You can customize the response body.
You have created an app.
- Log in to the SparkRTC console.
- In the navigation pane, choose .
- Click Configure in the row of the app for which a recording callback needs to be created.
The Configuration page is displayed.
- In the Recording Callback area, click Edit and configure callback information, as shown in Figure 1.
- Callback URL: address of the server that receives callback information. Only the HTTP and HTTPS protocols are supported.
- Private Key: authentication key for recording callback. The key can contain 32 to 64 characters. For details about how to generate a recording callback authentication signature, see "How Do I Authenticate a Recording Callback?" in FAQs.
Callback Example
Table 1 describes the fields in a callback message body.
"event_type": "RECORD_FILE_COMPLETE",
"stream_name": "mystream",
"record_format": "HLS",
"download_url": "https://abc-rtc-bucket2.obs.cn-north-4.myhuaweicloud.com/Record/Record/5fcdf5651xxxxxx6f835d0d4.SparkRTC.myhuaweicloud.com/live/continuous_record/hls/mystream_2021-04-28-08-57-07/mystream_2021-04-28-08-57-07.m3u8",
"file_size": 26254952,
"record_duration": 65,
"start_time": "2021-04-28T08:56:57Z",
"end_time": "2021-04-28T08:58:02Z",
"width": 1280,
"height": 720,
"obs_location": "http://obs.cn-north-4.myhuaweicloud.com",
"obs_bucket": "abc-rtc-bucket2",
"obs_object": "Record/Record/5fcdf5651xxxxxx6f835d0d4.SparkRTC.myhuaweicloud.com/live/continuous_record/hls/mystream_2021-04-28-08-57-07/mystream_2021-04-28-08-57-07.m3u8",
"app_id": "5fcdf5651xxxxxx6f835d0d4",
"job_id": "608196a2fa1xxxxxx515147f32ef463b",
"room_id": "room01"
} Field | Description |
event_type | Notification event type. Values:
stream_name | Stream name. |
record_format | Recording format, which can be HLS and MP4. |
download_url | URL for downloading the recording. This field is used only when event_type is RECORD_FILE_COMPLETE. NOTE: The address cannot be used for playback. |
file_size | File size. Unit: byte. |
record_duration | Duration of a recording. Unit: second. This field is used only when event_type is RECORD_FILE_COMPLETE. |
start_time | UTC time when the recording starts, which is, time when the first frame is received. The format is YYYY-MM-DDThh:mm:ssZ. This field is used only when event_type is RECORD_FILE_COMPLETE. |
end_time | UTC time when the recording ends. The format is YYYY-MM-DDThh:mm:ssZ. This field is used only when event_type is RECORD_FILE_COMPLETE. |
width | Width of the recording. This field is used only when event_type is RECORD_FILE_COMPLETE. |
height | Height of the recording. This field is used only when event_type is RECORD_FILE_COMPLETE. |
obs_location | Region where the OBS bucket for storing the recording is located. This field is used only when event_type is RECORD_FILE_COMPLETE. |
obs_bucket | OBS bucket where the recording is stored. This field is used only when event_type is RECORD_FILE_COMPLETE. |
obs_object | OBS storage path. This field is used only when event_type is RECORD_FILE_COMPLETE. |
app_id | App ID. |
job_id | Recording task ID, which can be used to modify, view, or stop the task. |
room_id | Room ID. |
detail_message | Recording task status description. |
