Updated on 2024-11-25 GMT+08:00
The GaussDB connector allows you to connect applications with the GaussDB database, and manage data transmission.
GaussDB is a distributed relational database developed by Huawei. It uses a distributed architecture and features hybrid transactional/analytical processing (HTAP) capabilities. GaussDB supports intra-city deployment across AZs for zero data loss, petabytes of storage, and more than 1,000 nodes. It is highly available, reliable, secure, and scalable, and provides key capabilities including quick deployment, backup, restoration, monitoring, and alarm reporting for enterprises.
Creating a GaussDB Connection
  1. Log in to the new ROMA Connect console.
  2. In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
  3. Select the GaussDB connector.
  4. In the dialog box displayed, configure the connector and click OK.
    Name
    Enter the connector instance name.
    Region
    Select a region.
    Project
    Select a project.
    Instance
    Select an instance for subsequent connectivity verification.
    Connection and Security
    Select the connection mode for the database. Currently, the Default mode is supported. The system automatically concatenates data source connection character strings based on configured data.
    Host IP Address
    Enter the IP address of the database.
    Port
    Enter the port number for connecting to the database.
    Database Name
    Enter the name of the database to be connected.
    Username
    Enter the username used to connect to the database.
    Password
    Enter the password used to connect to the database.
    Enter the description of the connector to identify it.
Action
  • Obtaining records
  • Adding a record
  • Updating records
  • Deleting records
Configuring Parameters
Table 1 Obtaining records
Table Name
Enter the name of the data table to be queried.
Field Name
Enter the fields to be queried. Separate multiple field names with commas (,).
WHERE Condition
Enter the conditions for querying data.
Order By Field
Enter the sorting field of the returned result.
Limits
Enter the number of records displayed on each page in the returned result.
Offset
Enter the offset of the pagination query.
Table 2 Adding a record
Table Name
Enter the name of the data table to be inserted.
Data to Insert
Enter the target field value in single quotation marks.
Table 3 Updating records
Table Name
Enter the name of the data table to be updated.
Update Data
WHERE Condition
Enter the conditions for updating data.
Table 4 Deleting records
Table Name
Enter the name of the data table to be deleted.
WHERE Condition
Enter the conditions for deleting data.
