Oracle
Updated on 2024-11-25 GMT+08:00
The Oracle connector allows you to connect applications with the Oracle database, and manage data transmission.
  • Oracle is a relational database featuring high performance.
  • The default Oracle port number is 1521. The administrator can change the port number as required.
Creating an Oracle Connection
  1. Log in to the new ROMA Connect console.
  2. In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
  3. Select the Oracle connector.
  4. In the dialog box displayed, configure the connector and click OK.
    Name
    Enter the connector instance name.
    Region
    Select a region.
    Project
    Select a project.
    Instance
    Select an instance for subsequent connectivity verification.
    Connection and Security
    Select the connection mode for the database.
    • Default: The system automatically concatenates data source connection character strings based on configured data.
    • Professional: You need to specify the data source connection string manually.
    IP Address
    Required when Connection and Security is set to Default.
    Enter the IP address of the database.
    Port
    Enter the port number to which the database is connected.
    Database Name
    Enter the name of the database to be connected.
    Encoding Format
    Enter the encoding format of the database.
    Timeout
    Enter the timeout interval for connecting to the database.
    Connection String
    Required when Connection and Security is set to Professional.
    Enter the JDBC connection string of the Oracle database, for example, jdbc:oracle:thin:@{hostname}:{port}:{dbname}.
    Username
    Enter the username used to connect to the database.
    Password
    Enter the password used to connect to the database.
    Enter the description of the connector to identify it.
Action
Getting database changes
To obtain database changes in real time, enable LogMiner in the database.
Configuring Parameters
Table 1 Getting database changes
Table Name
Enter or select the name of the data table to get data changes.
Database Operations
Select the change operation on the database.
