MySQL
Updated on 2024-11-25 GMT+08:00
The MySQL connector allows you to connect applications with the MySQL database, and manage data transmission.
  • MySQL is a popular, open-source relational database widely used as the backend of web applications. It supports multiple operating systems, such as Windows, Linux, Unix, and macOS X. MySQL features high performance, reliability, and flexibility, and is popular among enterprises and developers.
  • The default MySQL port number is 3306. The administrator can change the port number as required. MySQL supports multiple storage engines, including InnoDB, MyISAM, and MEMORY. Each storage engine has its own pros and cons and can be configured flexibly.
Creating a MySQL Connection
  1. Log in to the new ROMA Connect console.
  2. In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
  3. Select the MySQL connector.
  4. In the dialog box displayed, configure the connector and click OK.
    Name
    Enter the connector instance name.
    Region
    Select a region.
    Project
    Select a project.
    Instance
    Select an instance for subsequent connectivity verification.
    Connection and Security
    Select the connection mode for the database. Currently, the Default mode is supported.
    IP Address
    Enter the IP address of the database.
    Port
    Enter the port number to which the database is connected.
    Database Name
    Enter the name of the database to be connected.
    Username
    Enter the username used to connect to the database.
    Password
    Enter the password used to connect to the database.
    Enter the description of the connector to identify it.
Action
Getting database changes
To obtain database changes in real time, enable binlog in the database.
Configuring Parameters
Table 1 Getting database changes
Table Name
Enter or select the name of the data table to get data changes.
Database Operations
Select the change operation on the database.
