Kafka
Kafka is a distributed streaming platform developed by LinkedIn. It features high throughput and low latency for massive amounts of real-time data streaming. Kafka consists of producers, consumers, and brokers. Producers send data to the Kafka cluster; consumers subscribe to the cluster and process the data; brokers are the core component of a Kafka cluster as they are responsible for storing and forwarding messages. Featuring scalability, high throughput, low latency, reliability, and durability, Kafka is widely used for big data processing, real-time data streaming, and log collection.
Creating a Kafka Connection
- Log in to the new ROMA Connect console.
- In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
- Select the Kafka connector.
- In the dialog box displayed, configure the connector and click OK.
Name
Enter the connector instance name.
Broker Address
Enter the Kafka broker address.
Authentication Mode
Select the authentication mode of Kafka.
- SSL
- None
SASL
Mandatory when Authentication Mode is set to SSL.
Select the SASL mechanism.
- PLAIN
- SCRAM-SHA-512
SSL Username
Enter the SSL username or application key.
SSL Password
Enter the SSL password.
SSL Certificate Format
Select the SSL certificate format.
- PEM
- JKS
SSL Certificate
Enter the Base64-encoded certificate content.
SSL Certificate Password
Enter the SSL certificate password.
Enter the description of the connector to identify it.
Action
Writing messages
Configuration Parameters
Parameter |
Description |
Topic |
Enter the topic to be listened. |
Partition |
Partition to which the message will be written. |
Key |
Key value of the message. |
Message |
Message content. |
Acks |
Producer acknowledgement.
KeySerializer |
Method of turning the key into bytes. The default value is org.apache.kafka.common.serialization.StringSerializer. |
ValueSerializer |
Method of turning the value into bytes. The default value is org.apache.kafka.common.serialization.StringSerializer. |
BufferMemorySize |
Total bytes of memory the producer can use to buffer records waiting to be sent to the server. The default value is 33554432. |
Retries |
Number of retries. |
